You dont happen to have part numbers on those boca bearings do you???
Upgrade motors for King of Shaves
Another great question..Comment
Boca Ultra Seal Hybrid Ceramics:
Flanged: SMF74C-YUU NB2
Non: SMR74C-YUUNB2
These are for the stock EKOS stingers.
________
DrugtestAttached FilesLast edited by FighterCat57; 02-15-2011, 12:03 AM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Theyre not TOO bad, they do cost a bit more than others, but as we've heard a million times its better to by smart once..
Now if we were talkin' cars and bashing, nope save your dime, but we're talkin' boats here. Reliabillity is key as a bearing submerged in water spinning profusely is an extreme situation.
These bearings last a LONG time you'd definitely go through 4-5 sets of regular bearings before noticing anything alarming on these
bottom line yes a considerable initial cost but cost effectiveness you're getting 2-3 times your money's worthComment
Boca Bearings company is the leader in ceramic and ceramic hybrid ball bearing supplier and technology for industrial, recreational and RC hobby applications.
Don't know of anyone that discounts them much if any. Boca Bearings are usually a one time purchase (in my experience) so really don't mind just paying retail for them.
I've been spinning mine over 30k in salt water for a while now... no troubles.
________
Romanian cookingLast edited by FighterCat57; 02-15-2011, 12:03 AM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Screw bearings. Run a bushing. When/If it wears out, replace it. Whats the need for a bearing? You're getting resistance in the flex in every little bend. Smooth bearings mean nothing when your prop is ripping through the water. We're not talking about free wheeling here, right?Comment
Well, I figured out the purpose of the teflon spacer in the stinger today. I noticed one of my prop shafts was really "wiggly" compared to the other. turns out the front bearing slid back towards the end of the stinger. The teflon tube is a spacer between the two bearings that keeps the front bearing from sliding backwards. The front bearing is inserted from the rear, then the spacer, then the rear bearing is pressed in place.(or super-glued like mine because it keeps coming out)
A metal spacer holds it solid..
Great observation.Comment
Good bearings are a paramount with these tiny sizes and high RPMs.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
VENOM EKOS 4S 5000mah LIKE BUTTER
bill,nice up-grade on the stingers
when the time comes that will be the set up i run with.
thanx for a great idea.......Comment
I agree. One thing I realized is you have to be real careful not to leave too much space between the stinger and drive dog because the prop shafts are a little short and too much space will cause the flex cable to ride inside the inner bearing instead of the prop shaft itself.Comment
