Flex Shaft Saver
  • sippirat
    • Feb 2010
    • 39
    Flex Shaft Saver
  • tharmer
    • 342
    I make my props from wood. If they come off, they'll float.
    -t
    • sippirat
      • Feb 2010
      • 39
      even with the shaft, dog and nut attached? gotta be pretty hard to find that little prop in a lake.
      • tharmer
        • 342
        Well, the hard nut mahogony is hand rubbed so it sparkles. Also, I've injected the hub and the wide part of the blades with Aero-gel so it actually floats.
        -t
          • 8011
          I use wheel collars on the cables of many of my FE boats. Tighten the set screw against the cable with the collar up against the collet - not the stuffing tube. This mounting keeps the cable in the boat and doesn't cause excessive vibration. Another option is slipping silicone fuel tubing over the cable inside the hull....
          • sippirat
            • Feb 2010
            • 39
            btt (pics)
            • VIKOS
              • Jan 2010
              • 204
              yes wheel collars or you can check any plane magazine or even tower hobbies for them..basically its like your motor coupler yet spinns freely so theres no torque on any bolts which is the root of flex shafts coming off. I'm still waiting on my flex shaft..seems 4 mm and only venom make them so its hard to even use another one...
              • mappo
                • Feb 2010
                • 488
                flex shaft saver
                Precision Lock Collars from servocity will do the trick
                http://www.servocity.com/html/collars.html
                Do you know what the biggest problem with the world is?
                That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
                • domwilson
                  Moderator
                  • 4408
                  Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
                  Government Moto:
                  • VIKOS
                    • Jan 2010
                    • 204
                    Just recieved my flex shafts in the mail and aluminum props..I guess venom doesn't change there web site stats everyday they recieve parts...don't have a collar saver but I guess we'll see what happens if I lose another shaft I think I'll be selling this boat for maybe one with a 540 single and call it a day...boats not made to lose shafts..shouldn't need to fly off all the time..if they are fixed right like say a screw hole to hold it in place...
                    • VIKOS
                      • Jan 2010
                      • 204
                      Got my shafts and cast props yesterday..stayed up till 3 in the morning set up greasing and adjusting trim..boat ran great today awesome..sure I was a lil scared to open her up alot in fear of losing another shaft and or prop..might go back to the plastic props just so if I do I won't be spending another 30 bucks for props...anyways my question is this you have to actually cut the flex shaft to fit..now how do you get the metal wounds not to unwrap themselfs or not so much unwrap but become loose and cause restriction from going into shaft housing and into the motor coupler..any remedies would be great..every time I install it it acts as if its been blocked off by something and the slightly unwrapped wounds actually cause it. ohhhh lol installed the props backwards and was trying to figure out why she kept going in reverse..so I switchs sides and she ran forward lol kinda funny..
                      • bill1473
                        • Jan 2010
                        • 46
                        I need flex shafts. Just venom and they said 2 weeks.
                        • Joe M
                          • Mar 2010
                          • 3
                          Hi i am new a this i am looking at the king of shave pro and cons and how fast are they
                          • Jeff Wohlt
                            • Jan 2008
                            • 2716
                            I now carry the venom shafts. I am waiting on more stubs as I sold several in two days. They are the same exact size and install easily.
                            You can go to my site if interested. I sell L and R and Both as a set.
                            www.rcraceboat.com
                            [email protected]
                            • VIKOS
                              • Jan 2010
                              • 204
                              So theres no need to cut cause even the venom shafts need about 5-6mm cut in order to fit..but I will be ordering from you and have already have your web site on my favorites and this is a very good thing and if quality is better I don't mind paying more. Ran the boat today hit some chop had a turn over..landed back top side up and kept driving so this hull is very strong to say the least..now i'm gona run it till the motors die or the ESC..I think with a bigger ESC you could easily run 5S lipos till they fry but if you take care of it and not full throttle your whole run this helps. I also noticed that there really is no point to full throttle from a stand still yet half throttle and once she starts plaining open up on the throttle..this saves battery and could be one reason the shafts keep getting lost... theres lil tricks you can do to keep this boat running good...I also use WD-40 after a fresh water flush thru the lines and let it sit since I run in the ocean with this boat...but thanks again for taking the time to sell these shafts we all need them more thna anything...
