I was told by Venom that most cables lost are due to coming out of the coupler and not tightening the set screws good. Always use locktite on those.
Flex Shaft Saver
Well maybe some couplers are in order as well. The smallest I use is 6/32.
I already have the specs on them and would be easy to make a better versionComment
Got my shafts and cast props yesterday..stayed up till 3 in the morning set up greasing and adjusting trim..boat ran great today awesome..sure I was a lil scared to open her up alot in fear of losing another shaft and or prop..might go back to the plastic props just so if I do I won't be spending another 30 bucks for props...anyways my question is this you have to actually cut the flex shaft to fit..now how do you get the metal wounds not to unwrap themselfs or not so much unwrap but become loose and cause restriction from going into shaft housing and into the motor coupler..any remedies would be great..every time I install it it acts as if its been blocked off by something and the slightly unwrapped wounds actually cause it. ohhhh lol installed the props backwards and was trying to figure out why she kept going in reverse..so I switchs sides and she ran forward lol kinda funny..Comment
Vikos, You have to be shure you have the right flex cable in the correct side or else the cables could unwind regardless of Solder or set screws.
The wire twist in the cables is opposite and if installed wrong it is not going to be good sooner than later. Just a caution, hopefully you have it right.Nortavlag Bulc
Someone told me the Octura Hex is hard to tighten in that area. I think they work great but you have to be able to get them tight.
The wiredrives are working great form the input I have gotten back from customers.
I am also now soldering the ends and they come with new stuffing tubes that fit perfectly.Comment
You have me thinking now Jeff. I better check I can do flex hex's. I still have some wire drive kicking about, maybe some couplers. LYK.Nortavlag Bulc
I would think you could get some wrenches in there and get them tight.Comment
I also had a couple people put the wrong cable in the wrong side because I did not mark them. There is an easy way to see which is left and right.Comment
Have I told anyone how much I hate Venom products?The ekos hull is nice, but the innards arent worth a hoot.Why would anyone buy a boat only to literally HAVE to put aftermarket parts in it to make it a dependable boat?I definitely learned the hard way from my mistake.Comment
