Spartan Shaft Size?
  • dag-nabit
    • Feb 2011
    • 775
    #31
    Originally posted by tomjr
    Ok.. Actually worth the try... But if use the .187 I don't think can use the Teflon inner liner...
    In case you missed my EDIT. Be sure to order a new collet at the same time.
    Kevin
    • Jeff Wohlt
      • Jan 2008
      • 2716
      #32
      If it were me and running any bigger power like 6S I WOULD remove the teflon and use a good marine grease on the cable and stub...I also like to grease and then put a few drops of regular 3n1 oil down them and the stub...makes it very slick. Not sure if OSEs are loctite or brazed versions but thought I would just go brazed since most want to run bigger motors and 6S. Yes, they are more time since they step and have to be threaded.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • tomjr
        • Feb 2011
        • 17
        #33
        Hi jeff,
        What do you mean by brazed ?
        Do you have the brazed flex shaft for the .187 ?
        Tom
        • Jeff Wohlt
          • Jan 2008
          • 2716
          #34
          Brazed is just that...not soldered. 30,000 psi tensil strength. 1200 degrees with a brazing rod. It is 56% silver that I use.
          www.rcraceboat.com
