Spartan Shaft Size?
  • Steven Vaccaro
    • 8724
    Spartan Shaft Size?
    Does anyone have any good measurements on the Traxxas Shaft? Reason I ask is I have a customer that lost his and traxxas is out of stock. I want to make some replacements.
    I need the following?
    Shaft diameter?
    Shaft length?
    Cable thickness?
    Cable length?
    Length(total) from End of Cable to tip of prop shaft?
  • JPriami
    N4FOX
    • 1675
    I've posted it in here. Ill find them and post.
    • JPriami
      N4FOX
      • 1675
      Total length of flex and stub shaft all together 15 ¼”
      Length from end (where collet goes) of the flex to start of the stub is 11 ½” And the flex is .150 diameter
      Stub is 3 ¾” long total
      From where the flex goes in & stub begins the shaft diameter of the stub is .195 for a length 2.60” then it recesses down to .187 diameter for a length of .700” then the rest is threads for .400”.
      Also the end of the flex where the collet goes is soldered.
      does that help?
      They have an oddball prop shaft size the goes through the strut bushing. it sucks
        • 9479
        would be good to offer a new strut to go with the new shaft?
        • dag-nabit
          • Feb 2011
          • 775
          Shaft diameter?
          Shaft length?
          Cable thickness?
          Cable length?
          If you build them, they will come. Especially if they are upgraded flex cable.
          You can count me in for two.
          Brushless makes a good point.
          Because of the odd ball sizing on the prop shaft, another option to consider is offering a new 3/16" strut assembly that will bolt on without modifications (easy for the less experienced), then any upgraded flex shaft that is long enough and with standard 3/16" prop shaft could be used.
          Also, the quality of the Teflon liner is suspect. Could be a dollar to made on good quality stuffing tube liners as well.
          Kevin
          • GeoVW72
            • Jun 2010
            • 258
            Just illustrating to concur with JPriami
            My guess is that the stub is 5mm to allow the use of standard ball bearings for the strut that has never materialized.
            Team Boca Bearings
            S&G Design
            • dag-nabit
              • Feb 2011
              • 775
              Very possible, .195" is 4.953mm
              Kevin
              • Jeff Wohlt
                • Jan 2008
                • 2716
                I have had several want to put wire drives in. I have the stock to do it as well.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • tomjr
                  • Feb 2011
                  • 17
                  Please have the flex cable upgraded for the spartan...
                  There is quite a number of guys playing the spartan here in singapore...
                  I am sure the respond will be great...
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    Is that step down for 3/16" props or 4mm props?
                    www.rcraceboat.com
                    • JPriami
                      N4FOX
                      • 1675
                      It's for 3/16 props Jeff.
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        Cool... nice they run a 5mm shaft. It would also be easy to do 187 cables.
                        www.rcraceboat.com
                        • Revo09
                          • 1
                          If this happens i want two for me.
                          • tomjr
                            • Feb 2011
                            • 17
                            I want 3 if its the upgraded shaft
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              Does anyone mind grinding their own flat for the dog? Should 187 cable be an option or is 150 enough?
                              www.rcraceboat.com
