Spartan Shaft Size?
  • JPriami
    N4FOX
    • 1675
    .187 option might be nice for those running upgraded setups with larger props. As long as the stock stuffing tube isn't a problem. I put a .187 aeromarine cable in mine and it felt ok dry spinning.
    Might need a new collet for the .187 cable? I didn't test fit that. Wouldn't be a bad idea to get a better collet anyways. The stock one is pretty light duty.
    • mavdriver
      • Dec 2010
      • 65
      .187 would be good LMK when they are available ? I`m going to try CC 1717 on my Spartan .
      • Jeff Wohlt
        • Jan 2008
        • 2716
        These are ready to go...just got the 5mm stock. I did not see them on OSE yet but I am sure he is getting some made. These will be brazed like the Hughey shafts. 150 and 187 size. They are factory specs.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • mavdriver
          • Dec 2010
          • 65
          Jeff does the 187 size fit in the stock stuffing tube , strut ?
          • dag-nabit
            • Feb 2011
            • 775
            Just scooped 2 of them.
            Kevin
            • mavdriver
              • Dec 2010
              • 65
              Kevin
              what size ?
              • dag-nabit
                • Feb 2011
                • 775
                Originally posted by mavdriver
                what size ?
                I went with the .150 to match stock size.
                Kevin
                • tomjr
                  • Feb 2011
                  • 17
                  #23
                  Is the spartan upgraded cable ready ?
                  Did not see it at the ose web shop.
                  • mavdriver
                    • Dec 2010
                    • 65
                    #24
                    I`m curios if the 187 would work
                    • dag-nabit
                      • Feb 2011
                      • 775
                      #25
                      OSE doesn't have them yet, Jeff does.
                      Click the rcraceboat.com link in his signature line.
                      Kevin
                      • dag-nabit
                        • Feb 2011
                        • 775
                        #26
                        Not sure. The .187 shaft is nearly 1mm larger diameter. I think you would need to either remove the teflon liner, or replace the stuffing tube and liner with a larger diameter setup.
                        This is just a guess, but it is why I went with stock sizing. I'm thinking a better quality cable should do the trick without going larger.
                        But I'm not looking to run extreme prop sizes and try to break speed records.
                        Kevin
                        • mavdriver
                          • Dec 2010
                          • 65
                          #27
                          Kevin will do the same then thanks .
                          Ed
                          • tomjr
                            • Feb 2011
                            • 17
                            #28
                            Kevin
                            Hi Kevin,
                            Will the upgraded shaft solve the shaft overheating problem ?
                            The reason why the shaft overheat is due to the traxxas crap quality shaft ?
                            I have the same problem...should we go bigger on the flex shaft or remain the same ??
                            • dag-nabit
                              • Feb 2011
                              • 775
                              #29
                              Hi Kevin,
                              I really don't have the experience to answer that question.
                              I don't know that anyone knows for certain what is causing some spartan stuffing tubes to heat up, but I think the general theory is that the shaft is low quality and is "corkscrewing" inside the stuffing tube causing friction.
                              A high quality flex shaft should minimize the corkscrew effect, so I'm banking on a good quality flex shaft working for my setup.
                              I'm guessing Jeff is offering the larger flex shaft size for fellows like JPriami (or Brushless55 if he ever drops that CC1717 into his Spartan, hint hint, poke poke) that plan to push the hull to it's limits by running large, hi torque motors, and large props.
                              Those setups will place extra demand on the drive line.
                              Hopefully some of the more experienced boaters will drop in and give us the straight goods.
                              Kevin
                              EDIT: and keep in mind, if you go to the larger cable size, you will need to replace your collet as well.
                              • tomjr
                                • Feb 2011
                                • 17
                                #30
                                Ok.. Actually worth the try... But if use the .187 I don't think can use the Teflon inner liner...
