Traxxas Titan
This topic is closed.
Don't bother with a hobby store..
Steven here at OSE has the goods!
http://www.offshoreelectrics.com/pro...series&cat=134.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
I have a 1717 in a Losi XXL Monster truck running on 6s, The truck is roughly 16+lbs and that motor yanks it around like it's a matchbox car.
I bet it would be a great motor for it, tons of torque !Comment
im guessn its probally just about the wieght of a 30" mono due to abs; so im guessn that motor is pretty good
If all of your wishes are granted, many of your dreams will be destroyed!Comment
Yes it does look good, and let's face it... If u upgrade the motor much a bigger esc will be in order which kind of ruins the clean looks ofthe well thought out electronics tray.... I'm gonna keep mine stock for awhile.... I still remember the first time I whipped out my erevo at a house party on 6s!! Everyone was impressed to say the least.... Traxxas knows how to create attention, and this doesn't look like it's going to dissapoint! :)Comment
stock these look so clean, and 50mph to boot!
I understand where you guys are coming from but wouldn't the 1518 be much more efficent even tho it's a slightly higher KV than the TRX motor ?
TRX doesn't make junk but the Castle Motors have to be built with higher tolerences and be more efficent than them ? They are a Steve NEU design after all.
Hull Type Deep-V
Dead Rise Angle 26 Degrees
Hull Length 36.5 Inches (927mm)
Overall length 40.8 (1037mm)
Beam 9.5 Inches (243mm)
Weight 72oz (2041g) = 4.5lbs
Speed Control Type Traxxas Velineon VXL-6s, Watercooled
Input Voltage 7-18 NiMH Cells, 2-6 LiPo Cells
(8.4-22.2 Volts DC)
BEC Voltage 6.0 VDC
BEC Current 3A
Power Wire 12 gauge Maxx Cable
Thermal Protection Thermal shutdown
Low Voltage Detection Yes (user enabled)
Motor (electric) Traxxas Velineon® 540XL Brushless, watercooled
Drive System Direct Drive, 0.150” Flex Cable
Outdrive Adjustable Aluminum
Prop 2-blade composite, 42x59mm
Transmitter TQ 2.4GHz High Output with Traxxas Link™
Receiver 2218 2.4GHz Micro 5-channel
with Traxxas Link™
Servo 2056 High-torque waterproof
Batteries (2) Power Cell 7-cell
with High Current Connector
Charger Not included
Skill Level 2Comment
Yeah, It's a great motor, BUT it isnt a 6s motor. 5s may on that 1518. I had one, it's a great motor. Reguardlees of weight, once it has 6s in it, and being that it IS a big boat, it's still a lot to push. Notice only a 42 mm prop comes on the boat. Any bigger and the esc goes poof and the motor overheats.Comment
