FASTECH Performance TRICKS?
  • b.mcdaniel.2009
    • Sep 2010
    • 1641
    Just got my formula fastech and im running (2) 2s 5000mah 35c lipo's, stock motor/esc and prop. Does anyone know if there's some tweeks i can do to run a little bit faster like adjusting the hardware on the transome? Let me know guys .THANKS
    Oh also have 3s 4400mah packs on the way!!
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
  • JEDNJONES
    • Apr 2010
    • 134
    First thing to do is order an Octura X642 prop from here on OSE. Balanced/Sharpened. Trim the boat up out of the water to where its still stable enough for you. Bump timing to hi (need programming card) Also here on OSE. And she will reliably run 35 to 40 mph all day long with low temps. I wouldnt go more than 4S with that ESC.
    Jerry
    Fountain KOS P1, Formula Fastech, 37 Fightercat Daytona CF twin
    Pulled by Slash 4x4 tow vehical
    • lectriglide
      • 538
      Do some reading in this forum. There are multiple things you can do to make it perform better.
      This thread identifies a couple major ones. http://forums.offshoreelectrics.com/...ad.php?t=12302
      • Diesel6401
        Memento Vivere
        • 4203
        I hope you don't plan on running 6s on stock esc...
        - Diesel's Youtube
        - Diesel's Fleet
        • b.mcdaniel.2009
          • Sep 2010
          • 1641
          What not a good idea on 6s? What about adjusting the prop shaft angle up or down, or the adjustment on the transom of the boat?
          • Diesel6401
            Memento Vivere
            • 4203
            Stock esc is rated at 21v, 6s would be 22.2v. Although some of done it I would advise against. Run 5s instead, just make sure you disconnect the bec first and change the crappy stock 3.5mm bullet connector on the motor & esc to 5.5mm bullets. Also if you haven't done it yet dump those deans connectors ASAP.
            - Diesel's Youtube
            - Diesel's Fleet
            • BHChieftain
              Fast Electric Addict
              • 1964
              One other thing to consider-- there is no way to waterproof the hatch, so if you get too crazy with speed and turn it over, it will flood bigtime...
              Good news is so far my son has not been able to flip it, running 4S1P on x442, moving to x642 in a few weeks... darn stable hull...
              Chief
              • b.mcdaniel.2009
                • Sep 2010
                • 1641
                What do you mean 5s?
                • lectriglide
                  • 538
                  5s, like a 2s lipo and a 3s lipo in series.
                  • b.mcdaniel.2009
                    • Sep 2010
                    • 1641
                    oh okay thats what i thought.Thanks
                    • b.mcdaniel.2009
                      • Sep 2010
                      • 1641
                      so to make sure im following you, use a 2s and a 3s pack that are the same? and isnt my fastech wired in a series from the factory
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        Yes it is wired series from the factory. Take a 3s lipo and plug it into on side and a 2s and plug it into the other side. Packs the being the same means same "c" rating, mah and I try to use same brand. They should be identical besides the different voltages. Disconnect the bec (red wire) from the esc connection that plugs into the rx. Did you dump those deans connectos and change over the 3.5mm motor & esc connectors? I wouldn't run 5s until those things are done.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • b.mcdaniel.2009
                          • Sep 2010
                          • 1641
                          Why get rid of the deans? I've always ran deans for years in my trucks and cars, but never had a boat with this amount of power LOL! And im picking up those 5mm connections you said when the hooby store opens tomorrow!!!
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            Cars & trucks do not have near the amp pull boats due. Deans are limiting you, and so are the stock 3.5 connectors.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • b.mcdaniel.2009
                              • Sep 2010
                              • 1641
                              so what connections do you recommend?
