Little unstable on right turns
  • BHChieftain
    Fast Electric Addict
    • 1969
    Hi,
    Did a couple of runs with stock setup, plus X642 prop (picture shows a 440/3, but I swapped it out). I'm using the modified trim tabs (dogears) and fins. Boat is still a little unstable on right turns. We are probably going 1/4 to 1/2 throttle on the right turns, but if we start to power out of the corner she'll bounce around quite a bit and we need to back off. Left turns seem smoother.
    Check out the tab/fin alignment and let me know if these look ok, or should I try bending the fins even further out (this set of fins/tabs actually came from Jesse's old boat, that way I can return to stock setup easily on this boat).
    Thanks,
    -Chief
    PS, X642 is much better than 440/3 on this boat. No cavitation problems when pulling up to plane.
  • lectriglide
    • 538
    Try bending the fins out more. Here is a pic of Darin's boat with the handling suggestions that you or previous owners have done. The turn fins look bent out more that yours. If I remember, Jesse also modified it to where the batteries could go all the way back to the transom, so you might try moving the batteries toward the front a little at a time till you find the right COG. Moving them forward will make it ride a little "wetter" and increase the stability. Mine turns at full throttle but too quick a turn will make it hook.
    • BHChieftain
      • 1969
      I'll give that a try. But I'm wondering if maybe vertical fins combined with the dogears on the trim tabs might work-- I know on deep vees the fins should be // to the keel, but the bottom of the fastech is actually flat-- which makes me wonder it that's the reason it comes stock vertical...
      Anyway, I'll experiment with different configs and report back.
      -Chief
      • lectriglide
        • 538
        Read this thread first. According to Darin (Pro Boat Race Team) leaving them stock won't handle worth a darn.
        http://forums.offshoreelectrics.com/...ead.php?t=8080
        • LiPo Power
          DJI Drone Advanced Pilot
          • May 2009
          • 3186
          Originally posted by BHChieftain
          Hi,
          Thanks,
          -Chief
          Generally this boat will be little wigily on right turns. It did this to me also. She is great in left turns but I know I know..... Check on Jesses mods to fix this but stock will just be like that .....
          Canada
          • BHChieftain
            • 1969
            Working great!
            Bent the stabilizer fins out a little more to be perpendicular to the keel. What a difference-- she is running fantastic now. Here's a pic of the fin setup, and a video of our run today.
            -Chief
            • never2much
              • Jan 2010
              • 5
              nice adjustment
              I had the same problem with mine. I loosened the out drive and adjusted it up as far as it would go. I was going to buy new turn fins, but seing yours I will try bending mine as well. Great idea!!!!!
              • BHChieftain
                • 1969
                Credit goes to Darin! Note, try to get them perpendicular to the keel. On mine, you'll notice the left fin is bent out just a tad too much-- the right one is spot on.
                -Chief
                • lectriglide
                  • 538
                  Chief
                  Looking good. If you really want some fun, try a couple 2s lipos. It'll make you
