Your MG that started off as a hull
  • tagasagwan
    Molino Boater!!!
    • Jun 2008
    • 990
    #2116
    look what came in the mail today!
    Now I wonder where I can get a V-Hull for this baby?
    My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
    MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
    • skyman
      • May 2012
      • 290
      #2117
      Originally posted by tagasagwan
      here's how I do it. I first set the mount in the right angle and placement and apply small amount of ca glue just to hold it in place. then I bring it to mardon's place and have his worker apply epoxy resin mixed with fiberglass to permanently keep it in place. hehehe! in short, use ca first and apply fiberglass and resin. you may also use cf and cf resin.
      yea, that's the best way, i couldn't see any other way... when the fiberglass is applied how soon do you trim along the edges of the mount in order to get a nice clean look? that would be important esp. with cf. you would need nice clean edges to make it look good.
      Axial Yeti XL - Traxxas Slash 4x4 (x2) - Losi Mini 8ight - Tacon Soar Buggy - Blade 120SR - Miss Geico 29 (hull + parts)
      • skyman
        • May 2012
        • 290
        #2118
        Originally posted by macdon
        Find a removable plug that would fit the antennae.
        You'll find out later that if for any reason water gets in the hull - you'll find it hard wiggling the boat upside down just to get all the water out via the canopy opening. The antenna mount could be your drain.
        if water gets in the boat i'm in deep doodoo
        • tagasagwan
          Molino Boater!!!
          • Jun 2008
          • 990
          #2119
          resin dries in a minutes but a couple of hours i think is enough for you to trim it.
          • skyman
            • May 2012
            • 290
            #2120
            So what type of motorcycles do u repair/sell?
            My favorite show on tv is American Chopper on Discovery. Do u know it? Its almost like a male version of a soap opera. I love it! And u get to look at some beautiful bikes being built.
            Sent via Tapatalk
            • macdon
              • Jun 2011
              • 970
              #2121
              Oh you'll realize later on the many ways of how water enters the hull hehehe!
              • macdon
                • Jun 2011
                • 970
                #2122
                Shawn, Jason, et al
                Anybody looking for an Aeromarine Pro Cat?
                A friend I met earlier in Jim's Dock recently had a blow over wherein the front of his cat opened up like a mouth when it smacked the water. Check it out here:
                It is very repairable but he doesnt have the time to do it, so he is looking to sell his procat for $50 - $100. 50" long with a very nice green paintjob!
                Just thought I'd throw it out there.
                • macdon
                  • Jun 2011
                  • 970
                  #2123
                  I have a 42" Osprey if you're game!
                    • 7673
                    #2124
                    Here is my update
                    1. Offset Rudder Assembly: MG29 and MC29
                    2. Prop Strut with Mounting Bracket: MG29
                    3. Octura Prop X445, X645 or M445, M645 (not sure which to get or how to s/b/p)
                    http://www.offshoreelectrics.com/pro...?prod=oct-x445
                    http://www.offshoreelectrics.com/pro...?prod=oct-x645
                    http://www.offshoreelectrics.com/pro...?prod=oct-m445
                    which one should i get? which of these has given the best/fastest results? I would get the X445 and M645
                    4. Tail Ring
                    5. Bullet connectors (6mm)
                    http://www.hobbyking.com/hobbyking/s...idProduct=5281
                    6. Motor Mount
                    http://www.offshoreelectrics.com/pro...prod=ose-80610
                    not available yet You can get one at FC
                    7. Servo Mount for Traxxas servo 2075 (will buy only if wood is removed)
                    http://www.offshoreelectrics.com/pro...prod=ose-80090
                    8. Coupler/Collet
                    You may want to consider these:
                    http://www.offshoreelectrics.com/pro...ct-ocfhe5mm187
                    http://www.offshoreelectrics.com/pro...d=aero-coupler
                    shawn recommended this one, he said he's had great results with the fc oneGet the FC one
                    9. Rubber boot
                    10. Servo rod or Push rod w/ clevis (i don't think this one has the clevis)
                    any idea where i can get the one with the clevis?
                    11. Servo Arm - any recommendation? i can probably use the same one on the slash right? You may use that or Alloy for futaba.
                    12. Prop Shaft?? what the heck is this? You don't need one if you get a complete flex assembly as you have listed
                    13. Waterline/Tubing - how much of it do i need and what size
                    14. Screws - what screws should i get?
                    15. Break away bolt M3 x 15 (is this the right size?) and i can't find the corresponding plastic nuts
                    any idea where i can find the plastic nuts or should i just use regular metal one? Just use metal ones
                    16. 5A UBEC - which one do u recommend? Any brand with Input of up to 6S,Wrong Output 6Volts, 5Amps or higher.You only need 5s in this application so you can get a cheap one $5.FC had them but no longer. 6s and up are $30
                    17. Shawn's template for CF rails for the motor mount
                    shawn, is this for when you remove the wood? send it anyway :)I only removed the wood back to the bulkhead where the stuffing tube comes in.That is neccesary to get alignment and good fit.
                    18. Flex cable - .150 or .187 ?? Get the .187
                    is this the cable that goes through the stuffing tube? will that size fit? If you use the teflon you need a .150.Is it installed already?That is what I run.If there is no teflon then a .187
                    19. Flex Shaft
                    20. Flex Shaft Liner
                    20. Drive dog
                    https://www.philshobbyshop.com/catal...drive_dog_mg29 Make sure its for 3/16 shaft
                    21. Water outlets (how many do i need?)
                    http://www.philshobbyshop.com/catalo..._nut_sw36_tc31 2pcs.
                    22. Silicone liner??
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #2125
                      Catching up on this thread is hell, i think i just need to stay up later at night to catch you guys..
                      skyman no prob on the overcover bud,,Taga its painted CF not the realy thing but looks sweet in person..
                      Mac the link for that cat cant use it unless you have a username and such!!!
                      Skyman i ment inside the hull on the seem like Taga said, blueprinting is on the outside bottum off the ride pads..
                      If i forgot to reply to anyone im sorry ill try to catchup,,
                      • macdon
                        • Jun 2011
                        • 970
                        #2126
                        Oh sorry, I copied the pics and will post it here. Not too bad damage and very repairable. Just thought if someone is interested.
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          #2127
                          thats a bad azz looking paint job what a shame,,,, id destroy it trying to fix it, someones gotta take this baby!!
                          • macdon
                            • Jun 2011
                            • 970
                            #2128
                            The owner of that green boat is named Joe Mata and I got to know him a few weeks back when I bought his Futaba system in Jim's Dock. Thru our pm conversations, I learned that his dad is a Filipino and that they're planning a trip to visit the Philippines by the end of this year.
                            I'm sure he'll join our boating fun when he comes.
                            Here's more - he knows Jason as he traded with him more than once and I said its a coincidence since I know Jason as well! He said he plans to pm Jason if he'll be interested in this green pro cat as it was also Jason who got his busted Cat which Jason posted here in this thread a few months ago.
                            • skyman
                              • May 2012
                              • 290
                              #2129
                              first of all, thank you so much for your help guys... i appreciate it!
                              shawn, in reponse to your comments:
                              -are you saying to get both props? x445 and m645?
                              -how can i tell if the teflon is installed already? seems like there is another plastic tube inside the stuffing tube (ref. attached pic please)
                              • macdon
                                • Jun 2011
                                • 970
                                #2130
                                Yup, that right there is the Teflon tube. Just pull that white sorta plastic tube out since you're going bigger flex shaft anyway.
                                BTW - you see that green painted gas boat Cat I posted above? That's the reason why we reinforce the seams around the boat.
