yeah i know, i only used what was in their with the stock setup.. i didnt have any more tubing as i just started this hobby (addiction) about a month ago. Just ordered some and i make pick up a little from my LHS just so i can run it tomorrow. Well see how she does then with the lowered battery trays, ive heard thats the real trick.
Water..in my boat??
Got some new tubing and replaced about half of the stock tubing, all the tight stuff. No water inside, now i gotta work on the bounce..Comment
you can set the lvc to 3.2 v per cell. This happens on all my rc's the batts read a higher voltage on the charger then what the lvc is set at. Its just the batteries sagging under load and I've accepted it as normal. If you had an eagle tree logger you'd be able to know for sure.Comment
Alright ill try that, thanks. its really annoying to have my batts cut out only half way into my runyou can set the lvc to 3.2 v per cell. This happens on all my rc's the batts read a higher voltage on the charger then what the lvc is set at. Its just the batteries sagging under load and I've accepted it as normal. If you had an eagle tree logger you'd be able to know for sure.Comment
