Water..in my boat??
  • nosreme722
    • May 2011
    • 181
    Originally posted by ron1950
    lol u didnt hear the air excapping when u pressure tested the coolong system? anyway glad u found your problem......and u prob do need to get a little slack in the water lines
    yeah i know, i only used what was in their with the stock setup.. i didnt have any more tubing as i just started this hobby (addiction) about a month ago. Just ordered some and i make pick up a little from my LHS just so i can run it tomorrow. Well see how she does then with the lowered battery trays, ive heard thats the real trick.
    • nosreme722
      • May 2011
      • 181
      Got some new tubing and replaced about half of the stock tubing, all the tight stuff. No water inside, now i gotta work on the bounce..
      • TheShaughnessy
        • 1419
        Originally posted by nosreme722
        so how do i know if its at 3.4v per cell or just under load? and it stops at 3.8 every time.
        you can set the lvc to 3.2 v per cell. This happens on all my rc's the batts read a higher voltage on the charger then what the lvc is set at. Its just the batteries sagging under load and I've accepted it as normal. If you had an eagle tree logger you'd be able to know for sure.
        • nosreme722
          • May 2011
          • 181
          Alright ill try that, thanks. its really annoying to have my batts cut out only half way into my run
