Water..in my boat??
  • nosreme722
    • May 2011
    • 181
    Water..in my boat??
    Soo i think water is comin in through the shaft. When i open it up after a regular run its completely wet everywhere and theres sometimes pools of water in the sponsons
    theres no cracks or anything and i actually dried off my flex shaft and put extra lube on it right before my run..
    Also i have my lvc set for 3.4v (seaking 180a v2) and everytime i check my batts on the charger they read about 3.8v per cell? this has happened a few times consistently. Does the esc have a warning before the lvc or something? Am i going crazy and think that the lvc is cutting in when its not? Not sure but its cutting into my run times sooo.. not ok
    EDIT: if yo cant tell the pics r of the pools of water
  • ron1950
    • 3024
    thats alot of water.....have u pressure checked the water lines.....take the water line off the rudder ....put finger over exit and blow and find the leak if its in the cooling system .....what lube are u useing in the shaft?
    • nosreme722
      • May 2011
      • 181
      I know it never happened before i put the tacon and seaking in.. ill try that tomorrow thanks. I use the blue proboat marine grease.
      • dana
        Banned
        • Mar 2010
        • 3570
        the lvc kicks in under load. any boat you have should work this way
        • nosreme722
          • May 2011
          • 181
          so how do i know if its at 3.4v per cell or just under load? and it stops at 3.8 every time.
          • JPriami
            N4FOX
            • 1675
            You can also pressure check a system with a surenge full of water and plugging the line that goes out.
            • HYDROJERRY
              • Jan 2010
              • 2503
              I would bet its the motor cooler oring seals,, my miss elam was doing the same, massive water inside i brought it to work and put ower smoke tester on it and the oring in the rear of the motor was spraying water inside wright over the motor wires!!!
              • ron1950
                • 3024
                i am thinking the same thing jerry said...the o rings are leaking.....i have had some leak and just had to twist the cooler to stop leaks
                • nosreme722
                  • May 2011
                  • 181
                  Ya i think its that.. its way to much water for a small leak in the tubing, i did see a small drip when i tested the tubing but nothing major at all. Ill check the o-rings, i guarantee thats it. Thanks.
                  • Boaterguy
                    • 1760
                    Nosreme, I don't know if you are on RC groups but I recommended the orange juice container method, just put a small piece of tubing in an orange juice conatainer and blow on the hole, If you see water, it is your cooling system.
                    • nosreme722
                      • May 2011
                      • 181
                      The O-rings are fine? it was a little hard to get it off the motor even. The cooler came with 2 extra o-rings was i suppose to use those in the first place? i lost one anyway..
                      • ron1950
                        • 3024
                        maybe they were not seated properly oil them well and try putting it back on....then pressure test it again
                        • nosreme722
                          • May 2011
                          • 181
                          yep thats what i did.. put some more oil on it and put everything back together and put some water through it and this is what happened...
                          • CHIEFY_44
                            • Nov 2010
                            • 254
                            well for 1 you have too much tension on the water lines they are kinked you need to give them more freeplay, 2 that reciever you are running you don't need a bag on it it's full waterproof i run the same rx.
                            you will be suprised how much water will come out of the water lines on a 4 min run you have been lucky not to have fried the esc and possibly the motor, i have the same controller and mount it ahead of the motor that could help with your bounce problem too if you move it there. hope this helps
                            Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                            • ron1950
                              • 3024
                              lol u didnt hear the air excapping when u pressure tested the coolong system? anyway glad u found your problem......and u prob do need to get a little slack in the water lines
