Awsome.... thanks for the tips... I was going to use greatstuff but I've heard a lot of bad things about using. I used to build houses for a living so I'm extremely familiar with it and yes I gues if I just aply it in small amounts should be ok? How do you feel about making a ball of it so it expands and then cut the pieces to size that I need? We used to do that t fill holes we didn't want to blow out? Just curious if it would make a difference if I just stuck it in....
got miss g today started and finsished build
Lary, find your thread, highlight the URL, press control and the letter C. In the reply box, press the "link" tab. Now press contro V and tht should paste the URL in to the box. That should be all you need to post your links.Comment
Hey thanks for the tips guys I listened and applied and my boat ran great forgot to tape the hatch and almost zero water got in.... hatch nice and sturdy seemed well balanced with the battery suggestion the great stuff door and window foam was the ticket for me its non bowing... I wouldn't recomend the red can use the blue can it helps..... now if I can find the right prop for her. One that's already balanced cause that's a pain in the butt lolmiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
That's a good idea thanks guys... it can't be a harder to do than say bondo or drywall mud... I would assume... oh and jb I'm running 2 2s 5000mah 40c right now and just ordered 2 3s 5000mah 40c so I can try 5s and then the crazy 6s..... so yeah deffinetly gonna have to do some reinforcement... you guys have some fast boats how do you keep it from the nose coming up and flipping over that's my biggest concern right nowComment
you might get away with 5s, i cant say for sure. i was always told this is a 4s motor... you might search threads for the answers. i am running 4s on mine with a rather small prop x442 and i am trying to keep the hull in the water, let alone propping up. im nowhere near the speeds that can be acheived on 4s with this motor and the right prop so im gonna stick with props, and not more cells. jmoComment
this small of hull could work but dang the rpms! the right prop is needed.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
The esc can handle 210,000 rpms 2 pole 70,000 rpms 6 pole so that's good the 4074 2200 can handle 23vlts according to leopard
