Now I understand "Puff"
Is the OOB cable for the battery? If so, it does not matter with throttle calibration or lipo cell count. Throttle calibration is between transmitter and ESC for endpoints and neutral.Comment
If it were me, I'd do calibration individually. But you have to do them EXACTLY the same.Comment
Yes, each ESC should be calibrated independently with the throttle trim set at 0. Pull the ESC Y harness and plug only one ESC into the throttle channel of the receiver at a time. Calibrate the throttle by turning on the radio first, holding the throttle at 100%, then turn on the ESC and wait for it to beep (twice I think). release the throttle, I believe it will beep again, power down the ESC, and repeat with the remaining ESC plugged into the receiver.
This process is not successful until you see a solid green light on the ESC at full throttle under normal operating conditions.Vac-U-Tug Jr (13mph)Comment
Thanks everyone. I've got to call it a night. I have gone thru the calibration routine as described in the instructions. Regardless of the wiring combination, I never get the 2 beeps from the ESCs. I've tried doing ESCs together, individual ESCs. In every scenario, when I power up the ESC(s) I get the 6 beeps for 6 cells found. Never the 2 beeps for calibration.
In addition to the calibration, I will have to learn more about setting the throttle travel. Again, the instructions are awful. After one attempt I did get the reverse to rev much faster than any other time. Forward still sounds like about half of that.May your batteries never fail you...
MikeComment
It really sounds like the throttle channel is reversed, like several others have mentioned. The Dynamite ESC's do not have a programming option be to reversed, but the Spektrum DX2E radio does. There are two switches on the top of the transmitter, one labeled ST and the other TH, each with an N or R option. The throttle channel is the forward of the two switches, and reverse is the forward of the two positions. Please, for all that is holy, tell me that your TH switch is in the R position. That would explain a lot. It should be in the N position, and then you will need to change of the motor/ESC wires accordingly to get your props to spin correctly.Vac-U-Tug Jr (13mph)Comment
What's the deal with the default for TH. REV being "R" yet the throttle trigger states the direction is with TH. REV being "N"?
Untitled.jpgComment
FWIW - the Throttle Trigger inset picture on page 4 of the Zelos instructions make no sense to me. No idea what they are trying to tell me.
fweasel - the TH Rev switch is on R. We switched to N last night just to see what happened and of course everything was the reverse of what it was - trigger included. Yes, I could then switch 2 of the ESC/motor connections but I don't see what that would do to help get more speed.
Rereading what was posted last night I can't help but wonder if we are getting some terms mixed up. On page 9 of the Zelos instructions there is a Throttle Range Calibration. This is what I cannot get to work. Instead of the 2 beeps for calibration, I get 6 beeps for detecting 6 cells. On page 3 of the DX2E (transmitter) instructions there is a Travel Adjustment (endpoint) procedure. I believe this is what is limiting my throttle to 1/2 power.
I have found what looks like a valid method to set the Travel Adjustment. It could very well explain why I am getting only 1/2 throttle. This procedure is done only on the TX. After putting the TX in programming mode (yes the TX, nothing else) you turn the TH Trim knob all the way back (CCW), then pull trigger back and turn the knob (CW) all the way. You then do the exact same thing with the trigger at full brake. What I have been doing up to now was starting the knob at neutral (dead center) and then turning it all the way CW.
I'll have to wait until this evening to give this a try. I believe the Travel Adjustment must be set before you can do a Throttle Range Calibration.
I could be wrong but it's worth a try.May your batteries never fail you...
MikeComment
fweasel - the TH Rev switch is on R. We switched to N last night just to see what happened and of course everything was the reverse of what it was - trigger included. Yes, I could then switch 2 of the ESC/motor connections but I don't see what that would do to help get more speed.NEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6sComment
Make sure the cables are spinning the right way after swapping the motor wires.NEVER SATISFIED RACING
Need more hints? I think we are there folks! Made those 2 adjustments - shoulda done one at a time but I don't care. Did the throttle travel adjustment, switched to N, switched some motor connections. After that the throttle recalibration started to work. Motors are screaming like the first day OOB! Not sure if I can get to the water today but I have no doubt.
I did also notice the Y servo cable had a lot of dimples in the insulation and one spot where the insulation melted enough to stick to another wire so I replaced that.
Well I think we have a boat again. One good thing out of all this - I got to know a lot of you guys and you certainly got to know me. A big thanks to everyone. We stuck to it and got thru it.
Wonder what I can mess up next?May your batteries never fail you...
MikeComment
