I was thinking donut with these r/c's at full throttle lol
Now I understand "Puff"
Just to lighten things up a little. We all know the way my luck has been going. If it can go wrong it will.
This morning I was getting the boat ready. I put in at a private boat ramp and there's bulkheads on each side. I put the boat on the stand on the bulkheads and load the batteries and make the connections. Everything looked good so I picked up the boat took a few steps into the water and set her down. So I'm bumping the throttle to get beyond the ramp and out on open water. She's acting real squirrelly - trying to turn into a circle, not responding to the rudder. I'm sitting there thinking what in the heck happened now? She's too far out now to wade and get her, a few bumps in reverse got her back within reach. So I picked her out and I'm looking for the stand to set her on. NO STAND. Right then I hear a splash right under the boat. STAND. So that sucker was stuck to the hull when I first put the boat in and I suppose was causing all kinds of drag.
More than a few choice words on that.Comment
That's the problem. My instructions don't show a picture, they just describe it as "adjust the throttle end point". TX is a DX2E . Googling for the instructions show there may be more than one instruction set. I just found one that is for a DX2E but it is not my model. My instructions are SPM2330. This other one is SPM2332.May your batteries never fail you...
MikeComment
That's the problem. My instructions don't show a picture, they just describe it as "adjust the throttle end point". TX is a DX2E . Googling for the instructions show there may be more than one instruction set. I just found one that is for a DX2E but it is not my model. My instructions are SPM2330. This other one is SPM2332.Comment
MikeComment
It's on the Proboat site, no need to Google. http://www.proboatmodels.com/Product...rodID=PRB08021May your batteries never fail you...
MikeComment
Vinny - I was laughing to keep from crying. Yes, I did put her back in the water - nicelyLast edited by mikiek; 05-10-2017, 10:17 PM.May your batteries never fail you...
MikeComment
Ok, don't touch the trim when programming. Try it and report back. Set the trim as shown in the Zelos instructions.Comment
The green lights should go off when you start to apply throttle and turn on again as soon as you reach 100% throttle, which is how you know your ESC's and throttle are calibrated properly and delivering full power. If you don't get solid green lights when the throttle is at 100%, you are not sending full power to the motors.Vac-U-Tug Jr (13mph)Comment
MikeComment
The ESC does seem to be recognizing both batteries - I'm using 2 3S and a series harness per side at the moment. When I power up they beep 6 times which I believe means they see 6 cells.May your batteries never fail you...
MikeComment
Screen Shot 2017-05-10 at 9.01.01 PM.pngComment
