Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda -
Ok I did my test however I was only able to do 60.89mph and that is with only a prop change a pair of octura x447 sharp and balanced, battery temperatures where a little hot at 130f as you can see.
however I only had a pond 400 feet long, which is not so goo to measure speed.
I think you either need a longer place to run like you say or maybe some boat tuning. When I ran the 73mph runs with the x447s I was at 4mm on the struts and two 3s batteries as far forward as possible. When the batteries are that far forward they can only be strapped in by one Velcro strap each (at least with my packs anyway). Nice pictures!Comment
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Gotcha. I had two valves replaced. Ivebern having my zelos....before they were released to the public.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Well after running the boat for the 4th time out & hitting 75.7 Mph today. Watching the water coming out the side outlets I feel it should flow better than this. Tonight I gave the cooling system a closer inspection. Taking hoses off and blowing through parts of the system I noticed the esc's seem to be the most restrictive. Took the esc's off and wow those nipples have a tiny ID. So I took a 3/32 drill bit and opened them up a little. Here are a couple before and after shots. Looking forward to trying it out next weekend.
20160416_215012.jpgLand, Sea & Air, A true RC Addict.Comment
[ATTACH=CONFIG]142460[/ATTACH]
[ATTACH=CONFIG]142461[/ATTACH]Comment
Great speed and thanks for the cooling info. Have you cleaned the paint out of your cooling intakes? Mine was slightly restricted there. Not terrible but cleaning it out helped the flow.Comment
Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
I'm still using the stock flexes. I do plan to buy the stronger ones later on. But only because my flexes wore excessively due to the out drives not being properly assembled from the factory. Thus the grease kept getting sucked out the first 3 trips to the lake. For me the upgraded ones would offer a little extra piece of mind.Land, Sea & Air, A true RC Addict.Comment
