The best I can advise is to check the motor alignment. If the Teflon is worn now and there is no longer friction where there used to be, the issue is definitely alignment.
Because it sounds like your boat came this way, call our Product Support line and have them send you anther flex shaft with liner. Unfortunately they come in a pair, but I'm sure you wont mind having an extra flex shaft.
Once you install the new liner, make sure to align the motor properly. Please let me know if the misalignment is in the stuffing tube, which would prevent you from possibly aligning the drive line via the motor mount. Pictures help, so if you find this to be the case, post some pictures of the issue.
