so i got my 4s1p lipo today. i already wired the the esc for one pack and im running a receiver pack. i did evrything the way the tips n info section on here said. when i plugged evrything up to arm the esc smoke just poured out of it. i was told 4s was fine for the stock esc. can any one help me please
need help!!! lots of smoke
so i got my 4s1p lipo today. i already wired the the esc for one pack and im running a receiver pack. i did evrything the way the tips n info section on here said. when i plugged evrything up to arm the esc smoke just poured out of it. i was told 4s was fine for the stock esc. can any one help me pleaseMany issues!!! -
Happen to remove the red wire from the 3 wires coming from the esc and going to the receiver?
And there is no need to run a receiver pack with 4s.
You would have been fine with leaving it alone, wiring it up for 1 4s pack and running it.
Post pictures of everything inside your hull.Z
KBB34" Mono - Fast
ToySport Triton- Not as fastComment
I'm betting reversed polarity or some type of short from"wiring" it up. All you really need to do to set up the stock ESC is to put a single Dean's ultra plug in place of the series harness that it comes with.
Pictures will help confirm this.Don't get me startedComment
its wired exactly how the tips n info page on here says to run one pack with a receiver pack. and yes i did clip the red wire from the esc to the receiver. the smoke came from the back of the esc around the wires that go to the motor but those were all hooked up right also. the boat was running on one nimh 6 cell pack ( slow as hell) wired the same way. i didnt change anything but use a 4s1p 25c 5000 mah lipo. im totally confused right nowComment
thats how i wired it. i cant do pics i have an old school floppy disk digi cam with a laptop that wont take floppys lolComment
So the Deans is wired like this,with the red on the positive on both connectors?Attached FilesGovernment Moto:
"Why fix it? Blame someone else for breaking it."Comment
i hooked everything up to go through the arming procedure. it armed i gave the throttle a tap to see if it was running and it revved then once it stopped, sooo much smoke. i unplugged the pack pulled the esc out right away and checked everything and im lostComment
