need help!!! lots of smoke
  • z400
    • 1311
    #46
    Originally posted by Bill-SOCAL
    It has a cooling jacket built into it.
    Using the plug set up allows you to use two 2S packs in series if you want. Sometimes easier to get bteter weight distribution that way.
    Yeah i really dont know why this guy would want to run 1 4s pack in a Supervee.
    Boat is designed to be run on 2 packs at a time.
    You are either putting the boat off balance by only running 1 pack on 1 side of the boat or you are totally screwing up the COG when your placing that 1 battery in front of the motor.
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
    • 2ltrvtec
      • Jul 2009
      • 61
      #47
      im runnning one pack because less charge time, its cheaper to buy one pack, and i ran the boat on 12 cells and realized that with the batts way forward it planed quicker and was more stable at wot. the single pack in front of the motor sideways like port to starboard performs the same. im getting the delta force vortex anyway so ill rearrange everything in that hull. but why do i have to do what everyone else is doing? why do you have to give me a hard time because i would like to try something different? how about u just let me run it and ill report what happens and maybe youll be changing your setup.... it seems like evry forum theres a online bully. im on a lot of honda forums because i biuld engines and do motor swaps and theres always one or two dudes that are the same. this is a good forum though as far as info goes. and the only person been giving me a hard time is the z400 dude. if you dont like my setup stay out my thread
      • z400
        • 1311
        #48
        "Z400 dude"
        nice!
        Im not giving you a hard time, but thereis no need to act like i just discovered FE boating yesterday.
        You come here for help and when we help you, you trash talk.
        Us that own Supervee's know what they were designed for and know how to set them up.
        If you dont want our advice on what your doing right and what your doing wrong for the best performance then dont bother making threads.
        I'll stay out of all your threads from now on, that is no big deal at all.
        Good Luck "2ltrvtec Dude!"
        Z
        KBB34" Mono - Fast
        • 2ltrvtec
          • Jul 2009
          • 61
          #49
          "Z400 dude"
          nice!
          everyone was being helpful, you were quite condesending. yes im new to this hobby, yes im looking for advice. but i want to run one pack so im going to set my boat up for it. i dont wanna hear (read) someone basically saying im dumb for not running two packs. i would like suggestions about running the one pack. thats what i bought thats what im doing. i have alot of experience mechanically and when it comes to real boats so im not totally green i just havent been involved in the FE world. i was not trash talking anyone except you because of your real helpful info. i came on this forum to learn not argue with some dude ( yea i say dude because i live beachside in florida). if you have ran one pack the same way i am planning and it failed then tell me about. obviously 2 packs is easier but i had plans to change my hull so theres another reason for the one pack. im looking for help, info, and fun from this boat not forum drama
          • Bill-SOCAL
            • Nov 2007
            • 1404
            #50
            I'll simply add that there are an enormous number of SV27 boats out here in FE land. And the overwhelming majority of them run dual packs. Why? Because you can get a more optimal weight distribution and better CG placement. By your own admission you are running the boat wet, that is with the nose down.
            Most of us have found that a CG around 25% to 30% (6.75 to 8.1 inches forward of the transom) is the best performing point for the boat. Too far back and it flips easily. Too far forward and it runs wet, which is slow and draws more amps.
            I just stuck a 4S 5,000 pack I have as best I could right in front of the motor on mine and it balanced at 9.5 inches, or about 35%, that is a very wet running set up. This will make the boat more stable, but it will make it slower, make it run hotter, and give you lower run times due to higher amp draws. Evidence of hot runs is the fact that your ESC fried.
            So take this for what it is worth to you.
            Don't get me started
            • 2ltrvtec
              • Jul 2009
              • 61
              #51
              thank you for the info. im more than likely going to the vortex hydro anyways. i have another question about motor placement but i think it needs to go in the boat building forum. thanks for the input everyone ill let you guys know how it runs once i get the new esc.
              • 2ltrvtec
                • Jul 2009
                • 61
                #52
                i rearranged the sv this evening ill post pics in the morning for some opinions
