need help!!! lots of smoke
Hmm..... Definately sounds like something shorted out. I have ran mine on a single lipo many times without issue. I just made a jumper for one of the leads from the ESC and all was fine. I wonder if running on one 6c nimh might have caused too much heat to build up and started the beginning stage of burning up the ESC? I have seen some ESC's that have burned up if ran under voltage.
On another note, I have seen the floppy digital camera. They were one of the first to come out about 10 or 12 years ago. Worked very well at the time.Comment
yea i think the 6 cells damaged it and the lipo killed it. any suggestions on a new esc? i plan on getting the delta force vortex and swapping my sv parts into it. i might upgrade the motor and run 6s. which esc?? and yea that camera is old but works great.Comment
Get the UL-1 ESC. It will plug right into your SV motor. You could also use it wired as is with a 4S pack by simply using a plug wired to complete the circuit into the open plug where the second pack would normally go. That way you do not need to re-wire it, just make up a plug.
This is the SV-27 ESC: http://www3.towerhobbies.com/cgi-bin...SM&C=MJC&V=AQU
This is the UL-1 ESC: http://www3.towerhobbies.com/cgi-bin...&I=LXVSV4&P=SMDon't get me startedComment
This is the UL-1 ESC: http://www3.towerhobbies.com/cgi-bin...&I=LXVSV4&P=SMComment
It has a cooling jacket built into it.
Using the plug set up allows you to use two 2S packs in series if you want. Sometimes easier to get bteter weight distribution that way.Don't get me startedComment
