as a direct repacement type motor is the ammo worth useing as a stock upgrade as far as quality and power my factory motor still works fine if its not worth it ill leave it alone and work on other issues
ammo motors
The Ammo 36-50-2300 is an upgraded motor that is just a plug & go in the stock system. You will notice a vast improvement in speed with it."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
You will need to prop down a bit though. The Ammo needs to rev or it draws a lot of current.
X440 X637 or the Grim Racer 40mm X 52/3 blade all work well as a starting point.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Stock ESC, Ammo motor & Octura X642 run VERY well.
...ask me how I know."A quick temper will make a fool of you soon enough."
I had an SV27 that ran the ammo on an X642. It ran great except for the inherent Sv27 issue of being "belly up" (which had nothing to do with the motor or prop because she spent the same amount of time on her back with the stock setup) Dirtysouth31 ran the SV with an ammo on an X445 with no issues."A quick temper will make a fool of you soon enough."
Diesel
Yep, the CF40 should work. But as I said in the previous post they are starting points. Work your way up. As you can see others are running bigger props.
An X637/3 blade is another good one.
I haven't got one, but I reckon an M640 would be pretty quick.
Anyone out there tried that one? Or maybe the M642?
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
never mind.....I let the dogs out...Comment
