I am new to RC boats. I just got my Mini Rio a few days ago. When I ran it today it wouldn't even get up on plane. It was just plowing along slowly. I have seen a few supposedly "stock" Mini Rio videos on youtube and they are way faster than mine. Could mine be defective from the factory, or is there something I can tune to make it run faster. It sounds like it's cavitating. Any Ideas?
Aquacraft Mini Rio stock impressions
MikeVComment
I picked up mine from the LHS.
That motor pulls a lot of amps. an ESC suitable for that motor may be a bit big for the hull."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
It leans opposite the prop rotation right? That is torque roll. try to use a smaller prop."A quick temper will make a fool of you soon enough."
jfabcustom - check your prop to see if the leading edges are smooth. My father-in-law ran his into the sand a couple of times and the prop still looked good but the leading edge wasn't perfectly smooth and it wouldn't get up on plane.
RCman - are you using a 2-stick radio or a Pistix? If not, how are you getting the Thunderbird to arm? I'm using the same motor & speed control.Comment
The tube will have to be cut, but bending it is not necessary for this application.
I use this to cut my tubes, but any ol' hack saw should be fine.Sixty percent of the time, It works, Everytime!Comment
Hint, hint. No need to remove the stock stuffing tube. The mini cat hydro .098 flex with 3mm prop shaft fits great. its almost the perfect length also. The only change is the drive dog. It will drag unless the front(leading) edge is cut/sanded to a 45degreee angle.Sixty percent of the time, It works, Everytime!Comment
Hey Diegoboy did I piss you off somehow. Sorry if I did. Thanks again for your all help.Sixty percent of the time, It works, Everytime!Comment
Diegoboy what KV was your Ammo motor ??
ThanksPrince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
Video?
Video Link
it picks up weeds a lot in the vid, I was running on the Huron River
Mods:
- tore out the stuffing tube,
- upgraded to an OSE .095 flex drive.
- glass reienforced the inside.
- 3600KV motor from eBay kinda heavy
- a 35 / 45 A ESC, water cooled, also from eBay
-drive hardware: the micro strut and rudder from OSE
- Octura y534 Plastic prop
- 2S 1000 mAh, 30C Turnagy Lipo
It runs wonderfully, about 30 mph
I do have some prop heave to the side, but only out of the hole.
3S is next. Should be pretty fastCheetah, Super Rio, (Mod) Starship (Mod and sold),Comment
