Aquacraft Mini Rio stock impressions
  • Diegoboy
    • Mar 2007
    • 7244
    #76
    Then put a heat sink on it and forget the water....
    • Capgun_Slim
      • Jun 2008
      • 7
      #77
      Hey Diego, I love the machined rudders and other hardware you fabricated. Very Impressive. Any idea if you'll be making more, that you might want to sell? Or will Grim Racer possibly be making something similar, that can be mass marketed?
      • Diegoboy
        • Mar 2007
        • 7244
        #78
        They are very nice. I have 2 sets!. Lonewolf made them for me. He makes custom HW for just about any application. He's here, look him up.
        • rc freak 8892
          • Jul 2008
          • 1
          #79
          help
          would i be better off putting an 11.1 volt lipo or a brushless motor and can you run them both stock
          • Jon K
            • Jul 2008
            • 35
            #80
            Hey guys - got my boat in the water today - lots of fun... for 7 or so mins. I need more time! But I also want more speed.
            What is the most common upgrade on the motor? I am not really scared of electrical work at all, so I'd like to go to a brushless I think... but I need to know details!
            Also - in the meantime, what is the largest battery that fits in these things? Or, should I just buy multiple 1100mAH ones?
            • FE Wannabe
              • Jul 2007
              • 626
              #81
              Does anyone have any idea how many amps the stock Mini Rio ESC/Receiver can handle or how many amps the stock 380 motor draws? I am using this ESC/Receiver in my Mini V and I am thinking about upgrading to a Graupner 480 BB brushed motor for a little more speed. The Graupner draws 8.5amps at max efficiency.
              SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
              • dirtysouth31
                • 514
                #82
                Don't know how many amps.but I ran the same motor with the stock esc and it worked fine..wasn't much of a speed difference to me
                • FE Wannabe
                  • Jul 2007
                  • 626
                  #83
                  Thanks for the info Dirty!
                  I was hoping for a little more speed with the Graupner, but if there is not much difference, I can leave it stock and run it in my pool.
                  Brad
                  • RCman
                    • Jul 2008
                    • 7
                    #84
                    Originally posted by Diegoboy
                    I tried to hand drill out the coupler for the Ammo motor, It didn't work out. I ordered a pair of replacement couplers and a new wire cable (since AQ decided to discontinue the original ones and replace them with upgraded ones)
                    I couldn't wait any longer. I ripped out the stuffing tube, installed a bigger one, and went with the tried and true .098. I'm going to install a RX, and add a silicone cooling jacket and run her this weekend!
                    Diegoboy
                    is there any chance that i can get the links to the- couplers,stuffing tube,and wire cable parts that you have. love your boat, like to know who made those rudders would like to get some.
                    • Diegoboy
                      • Mar 2007
                      • 7244
                      #85
                      Sure...
                      Coupler: Octura Coupler Flex Hex 1/8" to .098 Cable
                      Stuffing tube: 3/16" Diameter pn#129
                      Flex Cable: Octura .098 cable system
                      Lonewolf made those rudders!
                      • RCman
                        • Jul 2008
                        • 7
                        #86
                        hey Diegoboy
                        the flex did you assemble it or would you let offshore assemble it and how much of the cable was used and can you show me how to cut flex cable. also did you have to cut the stuffing tube and did you have bend the tube to fit
                        Thanks
                        Wil
                        • Diegoboy
                          • Mar 2007
                          • 7244
                          #87
                          I assembled the flex cable myself, the "how-to" is laid out here. If you're unsure of your skills, just get the assembled one!
                          Not very much of the cable was used. In fact, if you buy another Stub/prop shaft, you'll have enough for another boat.
                          The method for cutting the flex cable is described in the last paragraph of the assembly info! (I cut mine in an unorthodox method.)
                          The tube will have to be cut, but bending it is not necessary for this application.
                          I use this to cut my tubes, but any ol' hack saw should be fine.
                          • Jon K
                            • Jul 2008
                            • 35
                            #88
                            Diego what motor are you using in that setup
                            • RCman
                              • Jul 2008
                              • 7
                              #89
                              diegoboy
                              would the mini cat racing mini hydro rudders work on the boat.
                              • Jon K
                                • Jul 2008
                                • 35
                                #90
                                Diego saw you are using the 28-35-2700.. I am looking at the 28-35-3900. Do you know what ESC I should use? Or, where did you get your 28-35-2700 because Tower says they're out of stock til Sept
