49.9mph Using M440 Octura
Awesome! Great! Thank you!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Today I tried my Hyperion G3 35c 4s 3300mah (4s2p) in my UL-1. The added weight and more forward arrangement of these batteries made the boat more stable crossing wakes. Speeds also appeared faster (no room for my GPS). Motor/ESC temps were about the same as before, but the new batteries were slightly cooler in upper 90's. I checked the temperature of my newly replaced Rubycon 1500uf Capacitor and it was 195 degrees... WOW capacitors can get really hot. I can see why the stock UL-1's smaller 680uf capacitor goes bad so easily. Adding one more should make them run a little cooler.
Ten Rubycon capacitors in picture were $12.71 shipped to my door. Thanks Longballlumber!
http://www.newark.com/rubycon/25zlh1...questid=246709Last edited by detox; 05-14-2009, 02:47 PM.Comment
Thanks for the update detox.. let us know your speed when you get your gps back in that boat...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
If you think about it get some temps on deans connectors too. I'm only running 2s 5250 30c and mine were @150 degrees.
Crash
You can put the GPS aft.Comment
Just to help clarify
The UL-1 Speedo has a SB (Stutter Bump) system as well as a LVC (Low Voltage Cutoff).. The UL-1 SB comes in at 12V and the LVC at 11.6. Just so you know we did not pick those numbers out of a hat.. We have tons of data regarding lipo discharge and also qualified our finding with some of the fastest FE RC boaters in the world.. True!
From our testing we have found about 15 to 25 second from SB to LVC.. more then enough time to get the boat back to shore.
Haivng said that there is certanly NOTHING wrong with only using part of the MAH the batts provide..
Hope this helps
GrimComment
I've hit the speed bump a couple times and was able to get her to shore before she cut out.
I'm still curious about those dean temps.
