49.9mph Using M440 Octura
Thanks to Alvinsmith75 recent post http://forums.offshoreelectrics.com/...ead.php?t=7630 I repaired my old damaged esc by soldering on a new capacitor (original capacitor failed). I remove the old capacitor then coated end of ESC using liquid electrical tape. Then I soldered on new capacitor to battery leads (yes there is a positive and negative side to a capacitor). I got the new capacitor from work so I am not sure if they make this version anymore (2000uf 25v).
I think these will work also
BTW...before a run be sure to tape down the Nose Canopy also. My Nose Piece flew off after hitting some rough chop. Nose piece floated as designed then I retrieved it.
Awesome! Glad it worked for you.
Caps were .90cents each. Sure beats buying a new ESC. Thanks Brian B.Comment
http://www.mouser.com/Search/Product...kqUyH0XnouY%3d.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Below is the cap that I added to my speed control. The cap helps smooth out voltage spikes the controller can see at times. I woulds say YES to you second question. I doesn't need to be "special" but it does need to be speced out correctly... Again, I have been using the below cap with out any problems.
http://www.newark.com/rubycon/25zlh1...questid=246709Comment
Thanks, does this go in between the battery and esc?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Yes...Solder negetive side of capacitor/capacitors to negetive battery wire and positive side of capacitor to positive battery wire. You can coat exposed wire using liquid electrical coating. This .56 cent cap fix beats spending another $90.00 for new UL-1 esc.
...Last edited by detox; 05-06-2009, 12:55 PM.Comment
It this what usualy goes on the esc? or causes it to fail?
and can you add extra on a good working esc?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
