49.9mph Using M440 Octura
  • detox
    • Jun 2008
    • 2318
    #31
    Awesome!
    It this what usualy goes on the esc? or causes it to fail?
    and can you add extra on a good working esc?
    Yes, Yes, and Yes
      • 9488
      #32
      Awesome! Great! Thank you!
      • detox
        • Jun 2008
        • 2318
        #33
        Today I tried my Hyperion G3 35c 4s 3300mah (4s2p) in my UL-1. The added weight and more forward arrangement of these batteries made the boat more stable crossing wakes. Speeds also appeared faster (no room for my GPS). Motor/ESC temps were about the same as before, but the new batteries were slightly cooler in upper 90's. I checked the temperature of my newly replaced Rubycon 1500uf Capacitor and it was 195 degrees... WOW capacitors can get really hot. I can see why the stock UL-1's smaller 680uf capacitor goes bad so easily. Adding one more should make them run a little cooler.
        Ten Rubycon capacitors in picture were $12.71 shipped to my door. Thanks Longballlumber!
        http://www.newark.com/rubycon/25zlh1...questid=246709
          • 9488
          #34
          Thanks for the update detox.. let us know your speed when you get your gps back in that boat..
          • detox
            • Jun 2008
            • 2318
            #35
            me no fit gps
            • Capt. Crash
              • Jan 2009
              • 301
              #36
              If you think about it get some temps on deans connectors too. I'm only running 2s 5250 30c and mine were @150 degrees.
              Crash
              You can put the GPS aft.
                • 9488
                #37
                Originally posted by detox
                me no fit gps
                can you put it in the back of the boat?
                • Capt. Crash
                  • Jan 2009
                  • 301
                  #38
                  Like this!
                  • detox
                    • Jun 2008
                    • 2318
                    #39
                    I guess I could mount GPS at rear, me forget.
                    Running 4s 2p 6600mah seems easier on the Dean's connectors than running 4s1p 5000mah.
                    • longballlumber
                      • 3132
                      #40
                      No Problem, it's a small price to pay for a little extra protection with very little risk invlolved.
                      Mike
                      • nate
                        • 1652
                        #41
                        Detox, Whats your run time on 4s2p???
                        LMT
                        LehnerMotorenTechnik.com
                        • detox
                          • Jun 2008
                          • 2318
                          #42
                          I try not to run them down to LVC because boat will stutter bump then suddenly stall on water. Then I will have to wade for it. But 6600mah should run longer than 5000mah...plenty long enough for me.
                          • Grimracer
                            • Nov 2008
                            • 662
                            #43
                            Just to help clarify
                            The UL-1 Speedo has a SB (Stutter Bump) system as well as a LVC (Low Voltage Cutoff).. The UL-1 SB comes in at 12V and the LVC at 11.6. Just so you know we did not pick those numbers out of a hat.. We have tons of data regarding lipo discharge and also qualified our finding with some of the fastest FE RC boaters in the world.. True!
                            From our testing we have found about 15 to 25 second from SB to LVC.. more then enough time to get the boat back to shore.
                            Haivng said that there is certanly NOTHING wrong with only using part of the MAH the batts provide..
                            Hope this helps
                            Grim
                            • detox
                              • Jun 2008
                              • 2318
                              #44
                              Cool Info...I will test the Stutter Bump and LVC again this evening.
                              • Capt. Crash
                                • Jan 2009
                                • 301
                                #45
                                I've hit the speed bump a couple times and was able to get her to shore before she cut out.
                                I'm still curious about those dean temps.
