Feigao 540XL in UL-1 !
    • 9479
    Just wondering if anyone has tried a Feigao XL in a UL-1?
    I have a 6XL in my Erevo and that truck is nuts on 4s and outright stupid on 6s!
    that motor keeps looking at me like it want's to go into the UL-1 !
    Not sure if I should try it or not?
  • detox
    • Jun 2008
    • 2310
    6xl is too hot using 4s lipo in the UL1. Perfect if using 3s lipo (3s2p)
      • 9479
      I was thinking of that..
      I have two 3s I could run parallel, the same way I run my truck on the track..
      • detox
        • Jun 2008
        • 2310
        Awsome. A Hydra 120 should work easily with that combo
          • 9479
          Great to know..
          What about the stock esc, would it work?
          • detox
            • Jun 2008
            • 2310
            I doubt it.
            • jingalls007
              • 1015
              Anyone's thought's on a 540XL using 4s and a 120 amp ESC in the UL-1?
              • Rumdog
                • 6453
                Can't beleive no one's doing this yet
                  • 9479
                  That's why I'ma askin..
                  • rcboatfan
                    • Aug 2008
                    • 253
                    just try it man!!!!
                    SUPERVEE 27 37'' TWIN CAT
                      • 9479
                      Originally posted by rcboatfan
                      just try it man!!!!
                      First I want to work on my Mean Machine...
                      single SV motor setup, and then I might try a twin!
                      • Xfactor
                        Banned
                        • 861
                        Im sure it will work but you probably need to step down to a 40mm or under prop maybe even a switch from x6xx series to x4xx series if a x6xx series is what you currently run.I think you could run 6s lipo on a 9xl with like a x432 thru 1732 series prop. All 32mm ,but youll probably cavitate. That's over 6oooo rpm at almost 3 hp.The motor will likely get warm too.A SAW set up?
                          • 9479
                          3hp only if the motor is pulling the amps....
                          32mm on this hull possibly not a good idea..
                          9XL on 6s is about the same as a 6XL on 4s for rpm
                          an 8XL would be a great choice on 4s or even a 7XL on 4s would be awesome to!
                          • Xfactor
                            Banned
                            • 861
                            Oh it can pull 100 amps but it will get warm
                            • Rumdog
                              • 6453
                              9xl on 6s is waaay too hot! No good!
