Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 what prop? PT hydro 1515 1Y - Offshore Electrics Forums
  • Make-a-Wake
    FE Rules!
    • 5557
    Originally posted by marko500
    unless your wife finds out how many boats you have or how much they cost. lol
    If my wife knew I had a grand in my 47 incher she would not be happy
    • fla350tt
      • Nov 2011
      • 340
      well I just ran the boat with a m445 and it is hauling butt. the gps only read 28 but it is not getting good recep. inside the hull. I raised the strut from 7/8 to 3/4 and put a little angle to raise the bow. it was flying. i am going to try another run with the gps on the outside.
      • detox
        • Jun 2008
        • 2318
        It sounds like your GPS is reading wrong. You should be running 50mph+ with that prop and setup.
        • fla350tt
          • Nov 2011
          • 340
          well i ran the boat again and the gps said 43, all i know is this thing is flying. when I turn the boat the speedrops way down so I will have to do some research and see why.
          • fla350tt
            • Nov 2011
            • 340
            well I ran the boat with a x640 and my speed was down, no change in set up from m445. so for now I will stay with the m445 until I can find some one to run with that has some knowledge to tell me if I need to do some set up changes. my temps are about 110 after 5 min.
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              Give the ABC H-5 prop a try. It's 6mph faster than the M445 on my hydro (33" Whiplash) so it could be similar on your PT. That was with an 8XL 2075 kv motor. But I also run it on a TP Power 2200kv motor in it too. It has a bit more lift than the M445 so you might need to raise the strut a smidge.
              http://www.offshoreelectrics.com/pro...p?prod=abc-H-5
              • fla350tt
                • Nov 2011
                • 340
                that prop has a bit more pitch than m445, what were your temps w/ the h-5
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  I seldom check the temps after a race anymore except with my finger as the setup is so predictable with either motor.
                  I think the temp was around 50c on the 8Xl & 48c with the TP Power motor when I did do it some time ago.
                  • fla350tt
                    • Nov 2011
                    • 340
                    well the boat has been with the painter for a few weeks, I can't wait till its done so i can get back to testing.
                    • egneg
                      • 4670
                      I would try a M545 if temps were good with the M445.
                      IMPBA 20481S D-12
                      • fla350tt
                        • Nov 2011
                        • 340
                        well i ran the boat at at club test and tune day a couple weeks ago. I had a x448 and boat ran great the guys at the pond were impressed for me being a first time boater. the gps said 52.2mph and was averaging over 220amps and temps were at 150* after 5 laps. someone helped me out and let me try a m445 back cut and and some other major cutting, 53.3 gps but flipped 210amps avg. but temps way down to 120*
