Prop Diagram
This is a sticky topic.
  • Steven Vaccaro
    • 8724
    Prop Diagram
    Steven Vaccaro
  • bwells
    • Jan 2009
    • 842
    Broken tip on the left side?
    • Steven Vaccaro
      • 8724
      I used a new prop, so it wasn't broke. I think it's the way I took the photo.
      Steven Vaccaro
      • Steven Vaccaro
        • 8724
        can you email it to me or try to attach it again?
        Steven Vaccaro
        • Fixitguy1
          • Nov 2016
          • 45
          Trying to find where to buy a b/s x440/3 I think it is a stainless steel for my Miss Geico 29 v3 all stock
          • Steven Vaccaro
            • 8724
            I just sent you a pm.
            Steven Vaccaro
            • Fixitguy1
              • Nov 2016
              • 45
              Miss Geico 29 v3
              I just received two Octura X440/3 props and both of them seem to have the same problem, they will not fit the drive dog.
              it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.
              • Steven Vaccaro
                • 8724
                Do you happen to have a picture? Sometimes the slots have to be opened.
                Steven Vaccaro
                • Peter A
                  • Sep 2012
                  • 1492
                  Use a 5/16" (8mm) od drive dog.
                  • ray schrauwen
                    • 9438
                    Yep use the little doggy.
                      • 7990
                      Removing material from the hub has less of an effect on practical balance than you may think. Removing 1/16" from the slot sounds like way too much however...
                      • Fixitguy1
                        • Nov 2016
                        • 45
                        The drive dog slots are fine the tongue material is covering the the drive dog slot on one only
                        • Fixitguy1
                          • Nov 2016
                          • 45
                          Hope you can see this.
