Prop Diagram
This is a sticky topic.
Tags: None
- Stuck
I used a new prop, so it wasn't broke. I think it's the way I took the photo.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
Great explanation and picture Steve need to be in a Read this first Newbe and yes for everyone.Do It Like You Mean It .....or Don't BotherComment
Steven,
Here is a copy of the latest Octura information sheet 9.2012 listing the Prop number, Diameter and then Pitch.
Makes it easier for me to follow and then make a decision on which ones to order.
MikeDo It Like You Mean It .....or Don't BotherComment
can you email it to me or try to attach it again?Steven Vaccaro
Miss Geico 29 v3
I just received two Octura X440/3 props and both of them seem to have the same problem, they will not fit the drive dog.
it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.Comment
it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.Steven Vaccaro
it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
