I need water cooling jacket for this motor any help much appreciated
  • Zackthrills
    • Apr 2013
    • 305
    hey guys I just purchased this motorLEOPARD 2030 12T KV7780 and I need to get a water cooling jacket for can anyone please help me find and water clean jacket for this motor I would much appreciate it here's the specs on the motor.Max. Current: 18A
    Lipo Cell: 2S
    Max. Power: 130W
    Rotational Speed: 7780KV
    Mounting Hole Depth: 2.5mm
    Shaft Diameter: 2.3mm
    Shaft Length: 10mm
    Dimensions (Diameter x Length): 20mm x 30mm
    Weight: 50g
    Suitable Model: RC Model Car / Boat
  • Gabe_k
    • Jan 2012
    • 126
    Lol you putting that into the geico?!
    2030 means the can is 20mm wide and 30mm long. Find a jacket that is 20mm ID but shorter in length than 30mm... I believe hobby king has them... But that's a month away:/
    • Zackthrills
      • Apr 2013
      • 305
      Us why do you think that will nurse to much for the mg17 ? Would you post a link to a water cooling jacket that will fit it please? I looked but was unable to find anything
      • Gabe_k
        • Jan 2012
        • 126
        http://www.offshoreelectrics.com/pro...?prod=gnd-4195
        Just run with this...
        • Gabe_k
          • Jan 2012
          • 126
          Should have gotten a 2045 like I told you... Right around 2500kv would be a rocket ship
          • Zackthrills
            • Apr 2013
            • 305
            I am going to order one this one i had already ordered two weeks ago
            • martin
              • 2869
              7780kv on 2s is way to high in a boat @ over 57000rpm unloaded.
              • Zackthrills
                • Apr 2013
                • 305
                Ok I'll just hang on to it then for another project. I have been using the minimono motor which is smaller then the 380 brushed motor it came with. What would you all recommend that i put in there. I think I'm going to use a motor like Gabe told me the 2045 what you guys think on that? Is that motor going to be small enough to fit in that boat.and the thing is is it has to be able to run on 3 s
                • larryrose11
                  • Jun 2010
                  • 761
                  In my limited experience with small boats, anything over 3600 KV is too much, unless you have room for 2 batteries. High KV don't produce that much torque.
                  Just so ya know, KV is Volts per RPM, but motor KT is Amp per Tq. As KV of a motor goes up, KT goes down. High KV motor will have low KT, and vice-versa. Its just the physics of the situation.
                  So, a high KV motor requires more amps to make the same torque as a lower KV motor of the same motor. High KV puts more strain on the small batteries and ESC's
                  • Heaving Earth
                    Banned
                    • Jun 2012
                    • 1877
                    Yup wayyyy to much kv.
                    • Zackthrills
                      • Apr 2013
                      • 305
                      awesome that's cool to know I didn't understand that you made it to where I can understand it I really appreciate that. I still need to know what size loader should I put in that if it originally came with us 380 brushed motor that would be equal to the same size?any suggestions on what motor to go with would be greatly appreciated
                      • Heaving Earth
                        Banned
                        • Jun 2012
                        • 1877
                        Leopard 2860 available at ose
                        • Zackthrills
                          • Apr 2013
                          • 305
                          Some thank you
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            sorry zack, i gave you the wrong kv for 2s. i was thinking 4s.
                            lets try this again
                            kv you want 4050kv
                            • Zackthrills
                              • Apr 2013
                              • 305
                              K need to run on 3s pack is that ok
