Also, any idea how quick it will be once i get the setup together?
Cat setup
DouggieComment
Not sure how much this will help you, but I just done a conversion of Proboats 31" thundercat. I am running a feiago 9t 580L, 2-3 cell 4000mah lipos, 150 etti w/o bec, with a octura x648 prop. Im running right at 40mph right now, but im still working the bugs out. I just went run it today and noticed that my wire harness was getting SUPER HOT!! So I just ordered some 6mm bullet connectors for everything and some 10ga wire to make my harness. Im not sure (and if someone can answer this) but I think that after I change my connections, I might get more speed because I dont think that the wiring I have right now can carry the amperage I am drawing. I was hoping to get close to 50mph, But its not as easy as it seems. I thought with all the power I have, It would have been no problem, but Im new to this and Im learning a lot everyday thanks to all the guys here.Also, I took a watercooling jacket from an old esc I had and placed in on top of the capacitors on the etti. I believe that you can not ever have to much cooling.
jjaj,
changing connector and wire size for something bigger change the circuitery resistance to a lower value, this simply gives more volt to the motor at the end!Comment
Lots of guys running the Turnigy(Hobbywing) i linked on 6S lipo,without problems.
Douggie is right though about certain ESCs not liking the maximum cell count at the rated ampage.
Those 220A hV escs's look a good bargain,if you could source one i would then go the single motor,Neu 1527 1.5Y on 10S lipo plus that HV esc.
Or you could go same controller plus a Scorpion 4035/800 motor on 10S.
Heres a good read for you;
I havnt run the HV esc so only going off what i have read.
I really only try to recomend products i've tried and tested myself..
Brod..
ps where are you in the UK?Slow gets boring fast.Comment
Deans are rated for 60Amp, on my 29" mono, the 540 8XL pulls around 70 constant (almost 100 burst) and the Deans are more than warm, almost hot, they dissipate heat so the internal resistance has to be considered seriously! resistance means power loss!Comment
No,sorry Matt,my bad typing,i meant this one http://www.rc4me.com/clearance/200a-esc-10s-opto.html
It looks a bargain IF you can get one.
Brod...Slow gets boring fast.Comment
that's the one I linked! £60!!!Comment
Looks good, my only concern is water cooling the monster
Also now created a shortlist of possible motors, drum role please.
Feigao 580 not sure what turn.
Scorpion 4020 / 3026 - seems some people have opted for the 4035 but want a boat not a plane
So what the general consensus on these? Will be running two of them.Comment
