Twin drive cats.....a discussion.
  • lomdel
    • Nov 2008
    • 708
    #61
    Does anyone know what size flex- and prop-shaft the SV27 stingers require? 3/16", 4mm, 1/8" or what size props? Steven, are they available in silver as well as on the above shown pic?
    • ozzie-crawl
      • Sep 2008
      • 2865
      #62
      the stingers are 3/16 and only come in blue
      • bustitup
        • Aug 2008
        • 3071
        #63
        Originally posted by ozzie-crawl
        just a thought on batterie wiring iam sure i have read some were about because the speedie is sensor based you can get trouble with the back emf when both escs go to both batteries (will try and find the thread) one problem i do see is if one batterie quits the one good batterie will see the load of both motors and if your one batterie cant cope with that amp draw there goes your second batterie as well
        if you scroll up and see the picture of the adaptor I posted I think it stops this problem you bring up...it is called an "unslow harness"....it was designed by a guy named unslow...do a search for it
        he made it to run two vxl systems in a revo or emaxx
        quote:
        To ensure even discharging on each system, it is a nice idea to use a little something called the ‘UNSLOW harness’. It essentially is a pair of leads with male plugs at one end, and female at the other, with a wire linking the negative wire on each lead, and the positive leads in the same way. This ensures that the batteries discharge at the same rate, preventing the LVC from kicking in on either system before the other- see below:
        • bustitup
          • Aug 2008
          • 3071
          #64
          Originally posted by bonewar
          OK GUYS, This is how i got around this problem, 2 different ways to go about it . Hope this helps. BONEWAR
          yes here bonewar has it just like the unslow with bullets instead of deans
          • lonewolf
            • Jul 2007
            • 658
            #65
            I might be totally offbase here and a bit late but thought I wouyld toos this in.
            It refers to paralelle connectors. From my learnings dump those cute lil connectors and get up to speed with the 5.5mm. Here is a link @ r/r(hope not to offend) that shows an awsome connector.....Id post the pic but im at work and cant really do that so here is the link...http://www.rumrunnerracing.com/fefor...ad.php?t=26691
            Cant get much less wire than this.... Hope it helps and I didnt offend anyone...Dave
            Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
            • peells
              • Jan 2008
              • 716
              #66
              Now that is clean I like it I will have to change to the 5mm connectors and like you I am at work as well (this stuff is adicting) and I like less wire it clutters things up
              Peter Eells; Fun, and Helping others To Have Fun!!!
              http://rcboatsbypetere.blogspot.com/
              [email protected]
              • bonewar
                • Jan 2008
                • 549
                #67
                Originally posted by peells
                Look at all that wire, here is a little device I cooked up last night,
                WE have been discussing this same thing on "yes another Catamaran build"
                Ok I had these connectors in my box they plug right into a Dean's so I used them.
                Pete
                Here you go Pete look at all the wire!!!! A few pics of the set up!!! BONEWAR
                SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                • peells
                  • Jan 2008
                  • 716
                  #68
                  very clean install!!!! very clean.
                  Great job! did you see the connector that lonewolf sent us to? I am considering changing
                  [email protected]
                  • bonewar
                    • Jan 2008
                    • 549
                    #69
                    Pete , I do like your idea, very neat. I'd like to see it finished!!! Lonewolf thats another great idea. Bonewar
                    • lonewolf
                      • Jul 2007
                      • 658
                      #70
                      I just finished makeing a set of the "par" connectors. I didnt use the rod in the middle i just held them in place with 2 heavier objects and got them tacked together. Then i flipped them over and added solder to the other side. I kept going trying to not get things too hot. I did get some 1 inch heat shrink but it was too small and just split once it started shrinking. No I dont have pics, Ive been soldering for about 3 hrs. Aside from boat stuff I also soldered up my crawler rig. Dual motors with a control switch to disenguage each motor as needed.
                      All in all it was fairly easy. I do recomend the .5.5 mm bullets to any boat running over 50 ish amps. The basic deans plug is rated for 60 amps max....
                      The only thing I use deans on is my crawlers and planes.
                      Good luck with the build. If you would like a build thread on a twin cat I have one at R/R link.....http://www.rumrunnerracing.com/fefor...ad.php?t=23909 There are a few pics of the build here but mostly after thought pics...
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        #71
                        i cant look at the pics from rum runner as they wont allow hotmail accounts but looking at bonewars it is very neat and not much wire used. i work for a electrical company and have been looking at some of the bus bars used to see if i can make somthing neat yet take high amperage, on my twin i will probably use deans as i shouldnt see any higher than 45 amps per side
                        • peells
                          • Jan 2008
                          • 716
                          #72
                          I work for an electrical contractor and we have some small copper bus bars lying around I might try and get a couple, but I was also entertaining the idea of trying my hand at the bullet connector Idea that Lonewolf posted to the red board.
                          [email protected]
                          • lomdel
                            • Nov 2008
                            • 708
                            #73
                            Have you guys seen this twin drive (I think?) newly released cat? http://www.venom-group.com/itemdesc.asp?ic=VEN%2D1810
                            • Eodman
                              • Sep 2007
                              • 1253
                              #74
                              I know I beat this dead horse all the time buuuut ..... How many of us really believe that Mid May delivery date??????
                              Wouldn't you think that they would have all kinds of info available somewhere as to the power, speed, etc...... If they were going to be available in just a couple of weeks!!!!!
                              We did it with a Bang!
                              Cats Are Where It's At!
