Twin drive cats.....a discussion.
  • ED66677
    • 1300
    #31
    In the case you run batts in //, if one esc burns and drain all the current both batt will smoke!
    I would go for two separate system 1 batt 1 ESC 1 motor, if one of them dies you can always drive the boat back to the shore!
    Emmanuel
    • ozzie-crawl
      • Sep 2008
      • 2865
      #32
      iam going to run each side with its own batterie pack. have read this is the better setup
      • lomdel
        • Nov 2008
        • 708
        #33
        with the parallel set-up. Great to have some kind of back-up. Ozzie, why is your motor-mounts so far forward? I know you said something about COG, but I would reckon shorten the drive-shafts and put the batts in the front . (You remember about my mounts?)
        • ozzie-crawl
          • Sep 2008
          • 2865
          #34
          yes i put the mounts up front to get my c.o.g rite, if i done it the other way around c.o.g would have been to far forward here is some pics show what i intend (hopeing to get your brackets done this week have to make them at work)
          • Gerwin Brommer
            • Dec 2008
            • 918
            #35
            Depends on how much amps you'r drawing.
            If you wanna save the lipo's you better run 2S per motor.
            • bonewar
              • Jan 2008
              • 549
              #36
              Originally posted by Simon.O.
              Here is another one for the twin users.
              If I am using two packs is it better to go for completely independant systems, being Battery-->Esc-->Motor.
              Or to go for a Paralell on the power side, being Pack+pack(2P)-->Esc's--> motors.
              Paralell power or independant setups??
              Simon , I would run the paks parallel, then you don't run the chance of drawing to many amps from 1 side of the boat. The lipos will stay balanced because both motors are seeing both packs. I ran the MARITIMO with the paks independent 2- 5 cell lipos , After the run 1 pak read 18V, the other pak read 17V. the pak that read the least v was the inside turning motor. SO that pak was under what i like to stop at 3.6V per cell. It was 3.4V per cell, now this was for about 5 Min run. I have changed to parallel now the lipos are staying balanced. MUCH SAFER!!!!! BONEWAR
              SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
              • lomdel
                • Nov 2008
                • 708
                #37
                This may sound stupid, but how would a wiring diagram look for a parallel set-up to two ESC's? Say I use 2x 4S packs parallel to two separate ESC's(?)
                • ED66677
                  • 1300
                  #38
                  both batt have the positive pole together as well as the negative one it is the same for the ESC's, so basically for 2 packs and 2 ESC'S you have 4 red wires together and same for the black ones.
                  Emmanuel
                  • Gerwin Brommer
                    • Dec 2008
                    • 918
                    #39
                    Simon :
                    Which lipos are we talking about ? ( capp. )
                    • crrcboatz
                      • Jan 2009
                      • 914
                      #40
                      If you run them parallel, doesn't that remove the possibility of the batt. being placed in the sponsons? I thought that was a very important requirement to a twin cat running well.
                      Curt
                      • Simon.O.
                        • Oct 2007
                        • 1521
                        #41
                        Gerwin
                        At the moment this is a theorey session, so hull, motor, esc and packs sizes are not decided on yet. I'm working on it
                        Curt
                        Wiring the packs in paralell does not determine thier placement.
                        I would see packs and motors in the sponsons and esc's on the tunnel top.
                        There would be very little more wire than in an independant setup.
                        I see the case for separation based on esc smoke leak
                        Given that I am now prone to over spec a whole power system to keep the strain off I can see the chance of esc failure as being reduced.
                        Bonewar pointed out the reality of running twins and has tried it both ways.
                        • crrcboatz
                          • Jan 2009
                          • 914
                          #42
                          It just seemed that running wires from both sides of the boat to a central site and the escs compounded the resistance with the extra wires necessary. Can someone post a drawing for the parallel battery setup leaving the batteries in the sponsons? How do you avoid extra wires? I almost have all I need to start the 36"Team Believer project using stingers on the sponsons, and my motor, esc and batteries in each sponson. Help appreciated.
                          • bonewar
                            • Jan 2008
                            • 549
                            #43
                            OK GUYS, This is how i got around this problem, 2 different ways to go about it . Hope this helps. BONEWAR
                            • peells
                              • Jan 2008
                              • 716
                              #44
                              Problem "No Problem"
                              Look at all that wire, here is a little device I cooked up last night,
                              WE have been discussing this same thing on "yes another Catamaran build"
                              Ok I had these connectors in my box they plug right into a Dean's so I used them.
                              Pete
                              Peter Eells; Fun, and Helping others To Have Fun!!!
                              http://rcboatsbypetere.blogspot.com/
                              [email protected]
                              • crrcboatz
                                • Jan 2009
                                • 914
                                #45
                                I like the KISS rule will stay with one batt. one esc, one motor in each sponson.
                                Curt
