I am playing with a renegade rigger with a 2600kv mile high outrunner, and was wondering what some of u guys have tried for props? I have tried a minicat racing prop which it didn't like at all, and also a 531 and 534, which it came with, but the best prop so far is a 632, which is bone stock, and was thinking about modding it? maybe detongue it, or cupping it or trimming the diameter.. was also thinking of trying a 1732..... what works best for u? I would be very interested to hear some ideas. thanks, Kerry
Renegade prop selection
I had best results with the one they advised ( plastic) . If you are not happy with the speed, I wld suggest adjusting the strut because the one they recommend pushes that hull about as far as it can go..< but I am a hacker, so experiment.Boats don't win races, drivers do. -
Steve Elias Suggested the X632. That's what I ran until I had a V935/3 cut down to 32mm. (V932/3) It screams on that prop!Last edited by Diegoboy; 02-23-2009, 08:42 AM."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
yes, I saw that.... I never had a lot of luck with 3 blades on my gasser 42"cat, they would run well on top, but cavitate bad coming out.... but this thing is completely different... deigo sounds like he has had his for quite a while, so I really appreciate the input.. I am hoping they get some instock soon... KerryLast edited by all8up; 02-25-2009, 09:27 AM.Comment
My renegade is the actual prototype built by Steve Elias. It's the very boat in the video, and the one pictured on the OSE video page. I've had her about 2 years now.
Contact Steven directly: Steven VaccaroIMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Ok, I got a 935/3 cut down to 32mm, and took it out.. It seemed squirrly and tried to crab sideways alot... I am thinking my rudder is not holding the prop torque.. the boat was fast.. I was wondering who did your prop work? maybe I need to send this prop out for work. thanksComment
I know the 632 runs and handles well... The 935 cavitates quite a bit more coming out, and then starts propwalking... I may need to cut the diameter down on it more, and or possibly roll the leading edges some. I'm not sure though.. I may need to change the setup for the prop.
so I guess a good question would be:
should I change the strut height or angle when going from a 2 to a 3 blade?Comment
I think Diego can give you the most valuable input regarding your question. We'll have to get him to measure.
Posting pictures of your current setup may also shed some light on what may be happening.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
sorry for the delay, here are some pics, I squared off the bottom of the strut, seems to help with the 2 blades, maybe not with the 3 blade.Comment
