HPR C5008 build. "Valkyrie"
  • vvviivvv
    • May 2009
    • 1079
    Hello all,
    I thought I'd share my 'dream' build with you all,
    it's being built with plenty of help from Manuel Wenny so we all know it's going to be a high quality boat..
    So far the specs
    Hpr 2.0 hull, 4 layers with seam reinforcement
    hardware is WD200, drives are longer than usual.
    Savox black edition servo
    Schulze 40.160 old
    Lehner 3060 / 6
    SLS QN 65C
    Abc 2515 cut to 62mm & Octura X465 prepped by Andy B
    I will do my best to add pics and keep it updated as the build progresses.
    The goal is to break 100mph comfortably without stressing the equipment.
    Uk SAW record holder
  • vvviivvv
    • May 2009
    • 1079
    power plant..
    & hull, alongside a hpr115 & my Mhz skater
    • vvviivvv
      • May 2009
      • 1079
      drives, collets and rudder
      one set of collets are for my 115.
      • vvviivvv
        • May 2009
        • 1079
        Some updates
        • vvviivvv
          • May 2009
          • 1079
          • fweasel
            master of some
            • Jul 2016
            • 4286
            Cool honeycomb material on the motor mounts. Is the filler material copper?
            Vac-U-Tug Jr (13mph)
            • vvviivvv
              • May 2009
              • 1079
              I believe the correct term is "Nomex Aramid Honeycomb"
              it's only for the motor mounts, the motors will also have the classic Lehner end supports, probably not needed with these motor mounts but better safe than sorry.
              • fweasel
                master of some
                • Jul 2016
                • 4286
                3060's are heavy motors. I wouldn't run them without the rear mounts.
                • vvviivvv
                  • May 2009
                  • 1079
                  yup, using them.. was just stating the kevlar fill on them motor mounts is rock solid.
                  • autolex
                    • Sep 2021
                    • 84
                    beautiful work! how are the epoxy lines kept so tidy?
                    MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7116
                      Hey Liam, gorgeous build!
                      Did you design and cut your own carbon?
                      If, would you have drawings for the hpr 115 you might share? Specifically looking for the motor mounts.
                      Thanks,
                      Jesse
                      "Look good doin' it"
                      See the fleet
                      • vvviivvv
                        • May 2009
                        • 1079
                        Hi Jesse,
                        Manuel wenny is the one who sorted all the carbon
                        I believe he has his own mounts for pretty much every hpr and a few other hulls (got
                        My exocet mounts from him)
                        I can ask, I don’t think they are for sharing amongst the general public but I’m sure he can supply you a custom set…
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4286
                          Thanks,
                          Jesse
                          Jesse, MBP sells a set for the C5009, not sure if it's the same pattern for the older 115 hull. They were very similar on the exterior, so possibly.
                          • vvviivvv
                            • May 2009
                            • 1079
                            and she's complete. just hope the painter can get the colour right and the exterior matches the interior.
                            • vvviivvv
                              • May 2009
                              • 1079
