50" TITUS Mono setup
  • Alfa Spirit
    • 2131
    Thanks all, I will start with 9S batteries. I have a pair of ZTW 150A HV esc, 12S max.
    • jkflow
      • Aug 2021
      • 329
      Always funny to see that people ask for advice, completely ignore it and go as planned because they didn't like the answer!
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        Hopefully now you all understand my reaction to the op..
        "Look good doin' it"
        See the fleet
        • Alfa Spirit
          • 2131
          Thank you for your help, with TPPower 4060 - 1100kV motors 2x8S or 2x9S is a good setup.
          I can have 2 x Turnigy 600 - 880kV, is it better to use those outrunners with 2x10S ?
          • Peter A
            • Sep 2012
            • 1486
            The one thing you have failed to answer is what are your expectations? Do you want to go zoom zoom, race or play? Also do you actually want anyone's advice?
            • Alfa Spirit
              • 2131
              I want a fast offshore, not a SAW boat for fun and race with friends.
              Turnigy 600 - 880kV specs :
              Turns: 10T
              Voltage: 6S~10S Lipoly
              RPM/V: 880kv
              Motor Poles: 8
              Internal resistance: 0.0145 Ohm
              Max Loading: 100A
              Max Power: 3700W
              Shaft Diameter: 6mm
              Shaft Length: 21mm
              Screw Mounting Spacing: 25mm/30mm (M4)
              Weight: 375g
              • Peter A
                • Sep 2012
                • 1486
                So what is your definition of fast? With the motors you are wanting to run the esc's will only take props in the 47-50mm range, which may well be inefficient on that hull size. On 880 kv I would recommend 8s, ztw200 esc's and props in the 55-60mm size for starters. You should see speeds in the 90 + kph range which is plenty in race water and giving you good reliability and runtime.
                • Alfa Spirit
                  • 2131
                  #23
                  I think that the good twin setup is 2 x TPPower 4060 - 1100kV and 2 x 8S or 2 x 9S.
                  • Jesse J
                    scale FE racer
                    • Aug 2008
                    • 7116
                    #24
                    Dang, you gonna actually put this thing in the water and hit go?
                    See the fleet
                    • Alfa Spirit
                      • 2131
                      #25
                      Originally posted by jesse j
                      dang, you gonna actually put this thing in the water and hit go?
                      lol
