50" TITUS Mono setup
  • Alfa Spirit
    • 2131
    Hi all, I have a TITUS 50" mono hull, here is the link : https://www.mhz-powerboats.com/shop/...49-61-gfk?c=67
    I want a twin setup for this boat, for a 50" mono what do you suggest, 2 x 8S, 2 x 10S or 2 x 12S? What is the correct voltage to start with? Thank you.
  • koen
    • Mar 2020
    • 361
    depending what motors you gone a use ( more V is less A)
    • Alfa Spirit
      • 2131
      My question concerns the most logical voltage for 50" mono offshore (Twin setup).
      I choose the motors according to the supply voltage.
      • koen
        • Mar 2020
        • 361
        it's a big hull so tp 5670/80 or lehner 3060 are the best option (to my opinion)how many kv's you want is how many S you need , problem is 12s is massif if you take a 8s and a 1220kv motor you keep the weight down and in combo with 2 lehner 3060 you get a missile
        • Peter A
          • Sep 2012
          • 1488
          What do you want to achieve, speed or runtime? What will fit your budget?
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7128
            Are you actually gonna build something or bust our chops when we give you recommendations??
            I won’t bite on this one.. been there done that.
            "Look good doin' it"
            See the fleet
            • Alfa Spirit
              • 2131
              I won?t bite on this one.. been there done that.
              • Alfa Spirit
                • 2131
                What do you think about 2 x 10S and TPPower 4060 - 1100 kV motors ?
                • photohoward1
                  • 1611
                  To high a KV for effective racing. Stick to 30k rpm. Nice big props maybe on the 470 or 465 range.
                  • koen
                    • Mar 2020
                    • 361
                    you can also go for a TP4070 850kv on 10s it's perfect
                    • photohoward1
                      • 1611
                      Perfect
                      • Jesse J
                        scale FE racer
                        • Aug 2008
                        • 7128
                        One motor to this
                        See the fleet
                        • Alfa Spirit
                          • 2131
                          Thank you for your help guys, I ' ve got the motors TPPower 4060 (40mm x 92mm) - 1100kV,
                          I can run with 2 x 9S batteries for a maximum RPM more appropriate. (?)
                          • Alfa Spirit
                            • 2131
                            MMProducts TITUS , 2 x 9S Twin setup - 36600 RPM unload
                            Is the 2 x 9S setup good enough ? Thank you.
                            • koen
                              • Mar 2020
                              • 361
                              stay with 8s to keep the rpm down
