I sprayed mine with corrosianX...... steve has it
HiModel 4s-8s 200 amp esc
I know Wurth but I did not know they make this kind of material! Any reference or name of the product?
EDIT : I think Steve can't ship any chemicals overseas, FastVee is in Finland!Comment
Yes, that´s the reason I cant get that corrosion-x.
I´m sure that Matti will soon reply with the Wurth product info.Comment
This may be another stupid question, but how do you guys connect 2x 2s packs on the esc?
-on sv esc there is 2 male deans and connecting wire to make series connection.
On HM esc there is only one positive and one negative lead.
Do you make a jumper wire that you use, or plug battery 1 positive wire to battery 2 negative and then plug this "one 4s pack" on the esc? -using bullets of course.
It does not make a difference I guess, but wanted to ask...Comment
Here is an easy to understand interactive page... http://www.offshoreelectrics.com/wiring.phpGovernment Moto:
"Why fix it? Blame someone else for breaking it."Comment
FastVee
I use your second option on all my setups. Plug the negative from one battery into the positive of the other battery. Then the other two wires into the ESC.
This eliminates extra wire & extra connections.
Of course this means that you need a male & female plug on each battery & the ESC.
There are a few different schools of thought on this setup but the way I do it is-
Female on the positive lead of the battery.
Male on the negative lead of the battery.
Female on the negative lead of the ESC.
Male on the positive lead of the ESC.
Here's a pic. Its the Aquacraft package but the same applies to all ESC. My HiModel ones are done the same way.
Cheers'
Paul.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Here is wurths chemical catalogue and in page 41 is that chemical that i have used "Kontakti SL" is chemicals name. I can`t find any english version of this catalogue but i hope this helps some how. http://www.arolatec.com/uploads/Wurt...empparit06.pdfComment
Section 3 - COMPOSITION / INFORMATION ON INGREDIENTS
NAME CAS RN %
1-methoxy-2-propanol 1320-67-8. 10-30
n-butyl acetate 123-86-4 10-30
ethyl acetate 141-78-6 1-20
hydrocarbon propellant 68476-85-7. 20-60
Maybe this is what it is made ofComment
I use the Himodel 200a on 6s2p in my delta force 33" mono. I did purchase mine with water cooling. No overheating issues at all.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
Motor is a Neu 1521 1y. No LVC, I normally make a couple wide open passes then bring her in.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
