Internal Water Cooling system Pump for large Catamaran
  • mxrb18
    • Jul 2019
    • 53
    Does anyone have any suggestions for a water cooling pump that would be sufficient in feeding both a TP-5680 and ZTW Seal 300A ESC? I am planning to run a dual water inlet that will feed both components separately for either side of the boat but I have been considering running a pump to really increase the cooling potential and prevent any cooling issues. If anyone has any brands or models that they recommend I would really appreciate any input. Thank you.
  • guchino
    • Jan 2018
    • 3
    How about this one.
    I use not only Gas but also FE boat.
    [URL="https://www.aliexpress.com/item/32730123173.html"]
    • MarkF
      dinogylipos.com
      • Mar 2008
      • 979
      The cooling I get off my rudders has been working very good for me for over 25 years. The only guys I have seen running a pump are saw boats that pull over 500 amps.
      • Alfa Spirit
        • 2131
        Use a pump only if the boat is too light .
        • RaceMechaniX
          • Sep 2007
          • 2821
          A pump is a good idea even for play boats that start and stop often. If room allows a single or pair of pumps will greatly increase the life of components especially if you are pushing power levels.
          Remember as soon as your boat slows so does the water supply. Latent heat in the motor windings and ESC will creep up quite high after hard running.
          I have been putting small pumps in almost all my boats except ones that don't need it. I use rather expensive, but compact pumps from www.micropumps.co.uk , but there many options.
          I use a 3.3V or 5V DC voltage regulator from Pololu so I can run off the receiver power.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • T.S.Davis
            • 6220
            Tyler, it looks like they sell on that's 6volt.
            Noisy person
            • RaceMechaniX
              • Sep 2007
              • 2821
              yes, but the 3V motor has a higher flow rate. https://micropumps.co.uk/TCSM200range.htm
              Tyler Garrard
              • guchino
                • Jan 2018
                • 3
                Fe boat 1300mm Mono 5860 970kv Ztw300a 12S
                Gas boat S520X2 1700mm Mono.
                Both good cooling.
                • mobius
                  • Mar 2019
                  • 9
                  Tyler, do you put it/them inline after the rudder/water pickup? The 3.2mm ID tubing seems small for a big boat.
                  • guchino
                    • Jan 2018
                    • 3
                    GAS from the bottom of the rear
                    FE from the rudder pick up.
                    Use large silicon tube (3.2mm?) The nipple has a slightly wider aperture
                    The water pump is used at 10 to 12 volts.
                    At high pressure there is enough water flow no problem with cooling.
                    This pump also good.
                    • mxrb18
                      • Jul 2019
                      • 53
                      Thanks everyone for the responses. I think I am going to run two of the MHZ pumps that guchino recommended. One per motor/esc combo with the pump coming from the bottom hull pickups to a "Y" which feeds each component simultaneously rather that running from the motor into the esc and then out of the boat. This I think will give me the best cooling performance running 12S. We'll see how it goes
                      • Jesse J
                        scale FE racer
                        • Aug 2008
                        • 7116
                        Only risk with using a Y instead of each component in line is that if one has more resistance, it will get less cooling.
                        "Look good doin' it"
                        See the fleet
                          Jesse is correct, using a “Y” is a poor method for maximum cooling of multiple components. Too, the OP will want to route the cooling water through the ESC first, then to the motor.
                          • Alfa Spirit
                            • 2131
                            A rudder with 2 water inlets is a good choice, parts available in all brands ,
