Delta Force 33 won't get up on plane
  • stadiumyamaha
    • 1284
    #31
    Paul, what parts of texas are you in? If in DFW I have some extra gear we could use to try and diagnose your issue. I think its your batteries myself. Sounds exactly like a cell that drops voltage under a load.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • jester_s1
      • Jun 2014
      • 82
      #32
      I'm in DFW too, Lake Worth in northwest Fort Worth to be exact. I usually run boats at Camp Joy park on Lake Worth. How about you?
      • stadiumyamaha
        • 1284
        #33
        I'm in keller, not far from you. Your over near river oaks?
        • jester_s1
          • Jun 2014
          • 82
          #34
          Yes, a bit closer to you than River Oaks.
          I resoldered all of the battery connections this evening. I had found one battery with cold joints, so I just went ahead and redid them all making sure they were hot enough. The little 25 watt iron is marginal for this. I also found that a motor mount screw had come loose, which I supposed could have caused some friction from misalignment. I'll go give it another shot tomorrow. If it still doesn't work, I'd love to take you up on the offer of help. Even if it does work, it would be fun to get together with another boater.
          • stadiumyamaha
            • 1284
            #35
            Keep me posted.
            • jester_s1
              • Jun 2014
              • 82
              #36
              I just wanted to let you guys know I finally got a successful run on my boat yesterday. It still needs some trimming and the cooling isn't good enough, but it's fast and stable. Thanks to all who helped.
              • gearhd48
                • May 2015
                • 139
                #37
                For what it's worth this was my fix to make sure all was cool on my df 35. DSC_0018.jpg
                SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.
                • gearhd48
                  • May 2015
                  • 139
                  #38
                  For what it's worth this was my fix to keeping things cool. DSC_0018.jpgDSC_0018.jpg
                  • jester_s1
                    • Jun 2014
                    • 82
                    #39
                    I may need to go that route. I'm going to see if modding the single intake is enough to get the job done first though.
                    • rol243
                      • Apr 2017
                      • 1038
                      #40
                      I have a delta 33 running on 4s with a 2200 kv motor / 180 esc and swinging a cnc 4214 x 3 blade. all runs cool with the single rudder intake.
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        #41
                        Originally posted by jester_s1
                        [ATTACH=CONFIG]160658[/ATTACH]
                        This is the interior layout of my boat. It had Deans connectors on it when I got it, so I upgraded to 6mm OSE connectors. In case it's not clear, the cooling goes to the ESC, then the motor. I used all medium diameter tubing, and there are no kinks. The cooling water exiting the hull was squirting out several inches when I made a part throttle pass just to check it.
                        Norwest- Could bad solder joints on the battery connectors cause overheating? I've heard of bad joints on the motor connectors doing that because they'll mess up the timing, but all I've ever heard of bad battery connections doing is making the connectors get hot. Or do you mean that overheating connectors could cause a low voltage condition? I did find one bad solder joint on a battery that I wasn't using in the test run but I did solder it at the same time I soldered the others. I'm going through them all now and making sure they are good.
                        Zooma- The boat was doing the low RPM get back to shore response to the throttle for a couple of minutes, then when I tried it on the bench it went to full throttle as normal. I assumed that meant heat, since it had had time to cool. Wouldn't a low voltage cutoff only reduce the power when the batteries show a problem under load and then recover immediately when they come back up? Also, I use these batteries in my Associated SC10, which is a fairly demanding power system too. I've never had a voltage drop in that application.
                        Jester.
                        From what I can see in that photo, you have the water outlet on the motor jacket underneath. The widely accepted position for it is at the highest position on the jacket. IE, in the 12 o'clock position.
                        This ensures that the jacket is full when under pressure. In your setup the jacket could be half empty. The water would flow from the low input at the front of the jacket to the low exit at the rear.
                        Rotate the jacket so that the outlet is in the 12 o'clock position. This will definitely reduce the temps on the motor.
                        I tend to bypass the cooling on the motor mount in my boats too. It doesn't do much. I also use 4mm internal diameter tubing to allow better water flow.
                        • CraigP
                          • May 2017
                          • 1464
                          #42
                          I use a thrust bearing on the motor and have the motor mount cooling in there to help keep the bearing cool. I would also remove it if I wasn’t running thrust bearings in my boats...
                          • gearhd48
                            • May 2015
                            • 139
                            #43
                            It could very well be the batteries! I have a 3s and all cell #'s show good, But it's 3yrs old and I get the same problem. If I put in my 1yr old 3s it goes well for 6 min. I'm thinking maybe a low amperage issue with battery....
                            • stadiumyamaha
                              • 1284
                              #44
                              A bad cell can show fine while idle but when under a load will drop voltage dramatically. If you have a voltage checker, you can hook it up and use a 12v light bulb hooked up with jumpers to the battery. If you check cells individually and one drops lower than the rest then you have a bad cell.
                              Again, again, your setup is so mild that if everything was in order you could almost get away without any cooling at all. Wouldn't advise it though.
                              • Norwest
                                • Mar 2014
                                • 165
                                #45
                                delete please.
