Motor choice for 6s jae 33
  • rol243
    • Apr 2017
    • 1038
    #31
    Originally posted by jim82
    What is the max width and height lipo that will fit?
    3 1/2 inches wide x 2 inches high. this height measurement is without the battery tray fitted, just velcro to floor is fine or velcro to sides if using 2 x 3 s packs.
    • urbs00007
      • Jun 2011
      • 826
      #32
      can anyone recommend a prop for my setup? leopard 4082 1600 kv. 6s 5,000 mah. seaking 180. thanks
      • jim82
        • Jan 2013
        • 1358
        #33
        I'm trying to find an h-7
        • jim82
          • Jan 2013
          • 1358
          #34
          Ty. For the measurements
          • jim82
            • Jan 2013
            • 1358
            #35
            I may end up with https://hobbyking.com/en_us/turnigy-...E&gclsrc=aw.ds
            • rol243
              • Apr 2017
              • 1038
              #36
              I would try and get a larger MAH pack than 4000 . zippy compact 5800 is about the same size or HRB 6000 .
              • rol243
                • Apr 2017
                • 1038
                #37
                O.S.E. parts store are out of stock, maybe find out when more are available or i know Hobby Supplies Australia have the H7.
                • jim82
                  • Jan 2013
                  • 1358
                  #38
                  looking for something other than zippy compact 60c not a big fan. I have some Turnigy hd's and they work pretty well but still looking atm.
                  • jim82
                    • Jan 2013
                    • 1358
                    #39
                    Kit arrived yesterday I'm hoping to start on it tonight
                    • rol243
                      • Apr 2017
                      • 1038
                      #40
                      jim, if your going to run 6s you might need to not fit the battery tray as height can be limited . just check before you glue up.
                      • jim82
                        • Jan 2013
                        • 1358
                        #41
                        I will ty sir
                        • jim82
                          • Jan 2013
                          • 1358
                          #42
                          So should I leave the battery tray mounts out too? This is where I am IMG_20180312_111343131.jpg
                          • jim82
                            • Jan 2013
                            • 1358
                            #43
                            I kinda answered my own question if I do use them my lipo is not going to fit. Just worried a little about tub strength without them.
                            • rol243
                              • Apr 2017
                              • 1038
                              #44
                              You can fit the 3 x cross rails but cut the center area down so the floor piece sits down almost to the tub floor, this way you have the extra strength and the side cut outs will be filled in. like you jig and clamps set up.
                              • jim82
                                • Jan 2013
                                • 1358
                                #45
                                I am going to add square strips to sides and maybe some wood filler to fill the holes on the outside.IMG_20180312_172304980.jpg
