Motor choice for 6s jae 33
  • jim82
    • Jan 2013
    • 1358
    #76
    That is when I just put the new bolts on about right here is where I have been setting it.IMG_20180328_192955563.jpg
    • rol243
      • Apr 2017
      • 1038
      #77
      I found with my 4s set up the fin needed to be raised approx 1/8 th inch at the trailing edge to stop speed flutter letting the sponsons ride a little wetter for choppy race conditions but for any calm water non race the fin was set with the top parallel to the top of sponson as in your last pic. overall c.o.g. balance seems to be quite good as the hull sits up nicely and handles very good at speed.
      • urbs00007
        • Jun 2011
        • 826
        #78
        does the boat track straight with no steering input?
        • rol243
          • Apr 2017
          • 1038
          #79
          Yes dead straight . i did set the right sponson to 3/16 inch tow - in.
          • urbs00007
            • Jun 2011
            • 826
            #80
            thanks
            • jim82
              • Jan 2013
              • 1358
              #81
              Changed bearings in my Tp3650 2060kv got it back in the boat now on 4s. First run with H-7 64.6mph if the wind would chill out I have a couple more props to try.
              • rol243
                • Apr 2017
                • 1038
                #82
                I have a T.P. 3650 - 2350 kv motor i would like to try in my JAE-33. currently running a HET 650-2200 motor and it is going very well or should i say was going very well until the modded h7 prop dropped off thanks to a dull prop nut.
                • jim82
                  • Jan 2013
                  • 1358
                  #83
                  Ouch. Blue Loctite man
                  • rol243
                    • Apr 2017
                    • 1038
                    #84
                    no i can,t rely on using locktite as it doesn,t set off quick enough when your changing over props. i will now use a new nut for every secound prop change as the nuts are dirt cheap to buy.
                    • jim82
                      • Jan 2013
                      • 1358
                      #85
                      Got a chance to run again today using a 2015. I'm up to 68.7mph and pretty sure she still has more in her with that same prop
                      • rol243
                        • Apr 2017
                        • 1038
                        #86
                        Jim, are you still running 4s power ? if so not sure if its the best idea to run lifting props on the jae unless the ski is removed , an octura x648 should get you over 70 mph in saw trim so i have been told. can,t complain about almost 69 mph though.
                        • jim82
                          • Jan 2013
                          • 1358
                          #87
                          Still running 4s yes with the Tp3650 2060kv. That's not a lifting prop but I have used both and results the same. Now when using a ski you can turn a bigger prop easier
                          • jim82
                            • Jan 2013
                            • 1358
                            #88
                            Same everything as last time made a slight turn fin adjustment. 69.6mph!
                            • rol243
                              • Apr 2017
                              • 1038
                              #89
                              Starting to get up some good speeds now Jim even with that size motor is good. I would like to try my 3650 - 2350 kv motor in the jae33 to see how she goes but at the moment i have a Het 750-2250 kv motor on 4s going very well, even stays with the Neu powered jae,s in club.
                              • jim82
                                • Jan 2013
                                • 1358
                                #90
                                Het makes good motors. I been thinking about getting one while I wait on a custom TP for the 12g I'm building
