2S Dark Horse 27 set up help
  • runzwithsizorz
    • Jan 2009
    • 856
    #31
    • TRUCKPULL
      • 2971
      #32
      You are not pulling your main batteries down, the problem is that a lot of ESC's want more then 2S input. and the internal bec system can not supply what is needed.
      Disconnect the red wire from the ESC going into the radio.
      Get a UBEC unit; I use these;
      https://www.offshoreelectrics.com/pr...rod=ker-HWUBEC
      I ran and raced the same setup as Darin for years.
      1515 .5Y 4400kv - 15 degrees timing
      CC - Hydra 240 ESC
      Ubec
      2 -2s -5000mah packs in parallel
      Custom - 538/3 prop
      My setup was HOT because of the custom prop, but the boat was unbeatable.
      I still run the same hull today in "P" Spec Sport Hydro
      Larry
      PS - does that ESC have auto timing- if so try that, I have read that Swordfish ESC's run cooler when set on Auto Timing.
      • bob horowitz
        • Apr 2016
        • 258
        #33
        I picked up a 6 volt NiMH 1800 mah battery pack to test with. Just wanted to see if the set up would work that way. If it works, I would definitely try a UBEC like you recommend. How do you wire it in? Do I just connect it to my main batteries before the ESC? After or before the capacitors? I do have it set on auto timing. I read the same thing somewhere as well. Until I get the USB programming dongle, I'll run it that way. From the chart on the Spectrum servos, it looks like it's a good digital servo so no problem there. It will take up 2S voltage. It looks like Darin gave me a really nice prop also. I think it's a tweaked up 634/3. Really thin and sharp with I think what's called a bar cut. Half round cut outs at the hub. I really want to get this boat going. I dinked with it at the end of last season and got nowhere. The ice is finally going from the pond that I use and I'm chomping at the bit. This seems like some real tangible info.
        Thanks for the help,
        Bob
        • TRUCKPULL
          • 2971
          #34
          Bob
          I wire the UBEC to the back of the ESC board where the black and red battery wires connect to the ESC board.
          Or you can solder them into the battery plugs on the ESC.
          Larry
          • bob horowitz
            • Apr 2016
            • 258
            #35
            Larry,
            Thanks for your help and suggestions. It seems that with your experience with this kind of setup and help I will actually get this boat running.
            Regards,
            Bob
            P.S. I will order UBEC tomorrow.
            • bob horowitz
              • Apr 2016
              • 258
              #36
              Success. I hooked up a separate RX battery pack and it worked like a charm. I have a separate BEC coming and I'll get that hooked up and hopefully that will work as well. Thanks guys for all the help. Now I can finally run this boat. Another day or so and the ice will be gone from my pond and I'll give it a shot. Larry, by the way the prop I have is a 637/3 tweaked up by Darin. What do you think?
              Again, thanks to all those who helped.
              Bob
              • fweasel
                master of some
                • Jul 2016
                • 4311
                #37
                What's the difference between running a dedicated Rx pack and a separate BEC? Do you need the BEC to use the Rx battery?
                Vac-U-Tug Jr (13mph)
                • TRUCKPULL
                  • 2971
                  #38
                  They are both the same, UBEC's do not need charging.
                  Do you need the BEC to use the Rx battery??
                  NEVER use the BEC in your ESC with any kind of external power.
                  Disconnect the red wire from the ESC going into your radio.
                  Larry
                  • TRUCKPULL
                    • 2971
                    #39
                    Bob
                    Darins prop - 637/3 - pitch - 59.2mm
                    My prop - Custom 538/3 - pitch - 57 mm - Detongued, Back cut, a little extra cup.
                    Both are close, depending on how the boat runs (very free)
                    Larry
                    • bob horowitz
                      • Apr 2016
                      • 258
                      #40
                      As I found today, if you use a separate RX pack, you just plug it straight into the RX. You have to cut the red wire from the ESC to the RX. At least that what works if your ESC has a built in BEC. I am bypassing the built in BEC and I'm going to use an external BEC which gets hooked up straight to the main lipo battery and then to the battery port on the RX. From what I understand, this helps get un interrupted power to the RX. I was experiencing enough of a voltage drop using the BEC in the ESC to make the RX stop working momentarily, there by losing control of the ESC. I'm a real newbie, so I might not be completely correct, but that's my understanding. All I know for sure is that by using a battery strictly for powering the RX, it eliminated my problem. Hopefully using the external BEC will do the same as the separate battery. The BEC weighs way less then the battery pack.
                      Regards,
                      Bob
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4311
                        #41
                        Ok, I get it. So, to recap, the BEC in your ESC is junk, yes?
                        • TRUCKPULL
                          • 2971
                          #42
                          As I said earlier, in a lot of ESC's the internal BEC does not like 2S input, they like 3S and up.
                          Also I have found that by running a UBEC, your ESC runs cooler, because the internal BEC is on the radio board of the ESC
                          Larry
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4311
                            #43
                            Missed that. Thanks for the lesson.
                            • TRUCKPULL
                              • 2971
                              #44
                              Instead of cutting the red wire
                              Here is a little trick that I use to disconnect the RED wire form the ESC to the radio.
                              I buy this 6" two wire servo extension, and this little blue plastic extension keeper from my local Hobby shop (RC Airplane stuff)
                              When you use this two wire extension there is no need to disconnect the RED wire from the ESC.
                              The little blue keeper stops them from coming apart due to vibration or a hard flip.
                              Now when you want to reprogram your ESC with a box or your PC, you do-not have to fiddle with trying to connect the RED wire back up again.
                              Larry
                              • bob horowitz
                                • Apr 2016
                                • 258
                                #45
                                My LHS only had a regular servo extension, so I cut the red wire in it and connected to the RX with it. Worked great. Should get my BEC Friday, maybe run the boat this weekend.
