I have a Dark Horse 27 that I bought from Darin Jordan. I have it set up with a Neu 1515 .5Y 4400Kv motor. It has a 3 blade 534 prop, with a Swordfish 220 amp pro esc and 2 Revo 420 Blend GO 5000mah 2S batteries in parallel. Other than the ESC, I believe it's the same set up that Dain ran. I seem to recall that I tried it with the LVC at 3.2volts, and when that didn't work I tried it at 0, and that didn't work either. I don't remember where I had the timing set, it was last summer and I have CRS. I haven't had any luck with my ESC set up. The motor will run for a few seconds and then quit. That's on the bench, with no load, so I haven't even put it in the water. I have the SW program box and I wondering if someone can give me some programing advice, particularly timing and LVC settings,I think I had the other settings correct. I understand that with this set up it's a real high amp draw, and I'll only get about 2 minutes run time. Any help would be greatly appreciated.
Thanks,
Bob
Thanks,
Bob
