stock class ques
  • waynedawg
    • Aug 2008
    • 132
    #31
    eodman will you be at these events?
    • waynedawg
      • Aug 2008
      • 132
      #32
      dr jet could you send me some pics of the bottom of your boat so i can see what i need to do cant see very well on the ones you posted tks wayne
      • Eodman
        • Sep 2007
        • 1253
        #33
        Iam going to try and make one least one event not sure which one yet! Maybe both!
        We did it with a Bang!
        Cats Are Where It's At!
        • waynedawg
          • Aug 2008
          • 132
          #34
          cool let me know the one your going to tks
          • n.h.schmidt
            • May 2007
            • 39
            #35
            700 motor
            Hi again
            Glad to see you are getting good advice. You mentioned that you have the 9.6 motor. If you went to the 700sc(sold here at Offshore) ,you could gain five or more mph. If you intended to race you would have to change the motor to have a chance. The 9.6s are dogs with 12 cells.
            n.h.schmidt
            • waynedawg
              • Aug 2008
              • 132
              #36
              ok thanks i am going to change the motor to the 700sc should i get the brush cooling on the new motor? its only 14 bucks more and is there a water cooling jacket for this motor?
              • n.h.schmidt
                • May 2007
                • 39
                #37
                Cooling a 700
                The tubes are good. The water jacket is good too,if you have room around the motor for it. Not every mount will allow for that.
                n.h.schmidt
                • waynedawg
                  • Aug 2008
                  • 132
                  #38
                  ok were would i get a water jacket for this motor?
                  • Dr. Jet
                    • Sep 2007
                    • 1707
                    #39
                    http://www.offshoreelectrics.com/pro...prod=cen-bjs02
                    I'll try to get some photos for you soon.
                    I like to use a generous amount heat transfer paste (from an electronics store) when mounting cooling coils. Clean the excess from the outside with denatured alcohol. It looks super-sanitary if you use some large shrink-tube over the coils when it is all assembled.
                    A nation of sheep breeds a government of wolves
                    • waynedawg
                      • Aug 2008
                      • 132
                      #40
                      ok so put shrink tubing around the motor and coils? ok on the pics tks
                      • Dr. Jet
                        • Sep 2007
                        • 1707
                        #41
                        Here's a couple of motors with coolinng coils. The S700 in the "Systems" is wrapped with Kapton tape (I didn't have any large enough shrink tube). The one in the rigger has clear shrink tube on it.
                        • waynedawg
                          • Aug 2008
                          • 132
                          #42
                          ok cool i think i got all the parts i need on a list now ill be starting on the hull when i get the pics. im going to a race in nj on nov 9th to check it out and meet some guys. i thank you for your help and ill keep you posted with pics on the rebuild that way you can tell me if im messing up thanks again
                          • waynedawg
                            • Aug 2008
                            • 132
                            #43
                            one other ques were should i put the water pickup tube? and what size should it be
                            • n.h.schmidt
                              • May 2007
                              • 39
                              #44
                              Motor angle
                              This may be difficult to make changes to,but you really need to angle your motor down. You have a way too sharp of a curve in your flex cable. Also as your power increases ,details make big differences . The flex cable in your boat needs support. It looks like its completely unsupported inside the boat. That teflon tube it runs in will not support it by itself. Under enough power the flex will try to knot up.
                              n.h.schmidt
                              • waynedawg
                                • Aug 2008
                                • 132
                                #45
                                ok i am getting another motor mount for it the cable needs to be on a striaght angle down? and also needs support under the shaft like a block of wood or something?
