looking for advie on next phyro
  • ray schrauwen
    • 9472
    Originally posted by Fluid
    For choppy water you will likely do better with a hull closer to 34". I have run the Insane and IMO it is really too small for rough water and 60+ mph. The Whips are okay but still struggle in the rough. There are several ML boats in my club and they run well in chop. One PT Stealth boat runs great in the rough but others struggle. One Delta Force 34 in the club runs surprisingly well up to 60 mph in rough water. It is difficult to pick a winner.For power a Neu 1521/1.5D (or equivalent) on 4S2P is tough to beat, the 1515 is too small IMO. I run converted water-cooled Castle aircraft controllers but in the larger hulls you could try the Castle Mamba controllers, several posters here have had good luck with them. An x450 is a good starting place, depending on the hull and how you run you could go up to an ABC 2016, perhaps bigger..
    Thank you. The 1521 1.5D I never thought to use. Running it in a Vortex sounds like a nice idea.
    • ray schrauwen
      • 9472
      Ray,
      The DF hull weighs in on my scale at 4.0lbs
      . The number sounds heavy-ish but this boat should, given its air-traps and wide "armpits" air out and run light and loose with moderate power - remember when 1515 1Y's were the "go-to" P motor ? Thing is that a sport hydro needs to use its power potential not only to rip up the straights but to maintain velocity throughout the turn with the rudder & turnfin digging in. I have a motor in mind that should be perfect but other projects are taking priority at the moment.
      Wow, its a heffer!
      • properchopper
        • 6968
        Wow, its a heffer!
        Not really. Weight "feel" is relative. If one picked up a one-inch square object that weighed 4 lbs it would appear very heavy. The rather widebody Vortex at 34" subjectively feels, at 4lbs really light for its size. With decent power I think this boat will be a foray into the future of P-Sport Hydro as the current crop of highly respected but crazy fast 30" hulls morph into a more survivable length. Just a feeling I have......
        • photohoward1
          • 1610
          Just ordered one to replace my whip 20. Got tired of blowin it over all the time.
          • ray schrauwen
            • 9472
            Grrrrrrr!
            • ray schrauwen
              • 9472
              I understand Tony. I thought my Cheetah would be a slug too but with a 1521 1.5D and a 452 it efficiently hauls the mail.
              • langevn
                • Mar 2015
                • 214
                what is the equivalent of a neu 1515 or 1521 1800kv-2000kv from an other brand ??? i find the neukind of exspensive
                  • 8011
                  http://www.offshoreelectrics.com/pro...=leo-4082Close enough, not quite the performance of the new but a lot less costly..
                  • langevn
                    • Mar 2015
                    • 214
                    hi everyone and thank for the advice i finaly pic the boat for next year it eh insane fe 30 and rtrthat purshace from somone it as a 4074 2200kv and 180 hobbywing v2 and the prop is m645 i tested it seem fast but i been reading arounf the forum what is the best prop for this set up to reach max speed >?? and also running 2 x 2s 7.5v 6200 mah 50c
                    • properchopper
                      • 6968
                      Frequently used heat race props for that setup are Octura M445 or M545. The 645 you asked me about in the PM will get you more speed. Are you looking for max speed in straightline runs or oval racing ?
                      • langevn
                        • Mar 2015
                        • 214
                        hi thank you for the respond and what i am looking is for both straightline runs and oval racing
                        • T.S.Davis
                          • 6220
                          #27
                          Whip 20 will work in the rough stuff but you have to build it heavy. Like 9 or 10 pounds RTR. Then you need lower KV with a big prop.
                          All these hulls are good. Just a different approach with each to get where you want to go.
                          Noisy person
                          • properchopper
                            • 6968
                            #28
                            Langevn,
                            The FE30 was designed as a dedicated oval heat racer. There's an optimum speed (and prop window) for speeds on the oval course as has been mentioned. If going at max speed in a straight line is your cup of tea, finding that zone involves removing the turn fin and going up in prop size in small increments until something bad happens.
                            Then again,
                            • langevn
                              • Mar 2015
                              • 214
                              #29
                              ok then wich prop will i need for speed in strait and oval iam in impba d1 for racing
                              • properchopper
                                • 6968
                                #30
                                from post #25 : Frequently used heat race props for that setup are Octura M445 or M545
