looking for advie on next phyro
Ray,
The DF hull weighs in on my scale at 4.0lbs. The number sounds heavy-ish but this boat should, given its air-traps and wide "armpits" air out and run light and loose with moderate power - remember when 1515 1Y's were the "go-to" P motor ? Thing is that a sport hydro needs to use its power potential not only to rip up the straights but to maintain velocity throughout the turn with the rudder & turnfin digging in. I have a motor in mind that should be perfect but other projects are taking priority at the moment.Nortavlag Bulc
Not really. Weight "feel" is relative. If one picked up a one-inch square object that weighed 4 lbs it would appear very heavy. The rather widebody Vortex at 34" subjectively feels, at 4lbs really light for its size. With decent power I think this boat will be a foray into the future of P-Sport Hydro as the current crop of highly respected but crazy fast 30" hulls morph into a more survivable length. Just a feeling I have......2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
Just ordered one to replace my whip 20. Got tired of blowin it over all the time.
Sent from my iPhone using TapatalkComment
Not really. Weight "feel" is relative. If one picked up a one-inch square object that weighed 4 lbs it would appear very heavy. The rather widebody Vortex at 34" subjectively feels, at 4lbs really light for its size. With decent power I think this boat will be a foray into the future of P-Sport Hydro as the current crop of highly respected but crazy fast 30" hulls morph into a more survivable length. Just a feeling I have......Nortavlag Bulc
http://www.offshoreelectrics.com/pro...=leo-4082Close enough, not quite the performance of the new but a lot less costly..ERROR 403 - This is not the page you are looking for
hi everyone and thank for the advice i finaly pic the boat for next year it eh insane fe 30 and rtrthat purshace from somone it as a 4074 2200kv and 180 hobbywing v2 and the prop is m645 i tested it seem fast but i been reading arounf the forum what is the best prop for this set up to reach max speed >?? and also running 2 x 2s 7.5v 6200 mah 50cComment
hi everyone and thank for the advice i finaly pic the boat for next year it eh insane fe 30 and rtrthat purshace from somone it as a 4074 2200kv and 180 hobbywing v2 and the prop is m645 i tested it seem fast but i been reading arounf the forum what is the best prop for this set up to reach max speed >?? and also running 2 x 2s 7.5v 6200 mah 50c2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Whip 20 will work in the rough stuff but you have to build it heavy. Like 9 or 10 pounds RTR. Then you need lower KV with a big prop.
All these hulls are good. Just a different approach with each to get where you want to go.Noisy personComment
Langevn,
The FE30 was designed as a dedicated oval heat racer. There's an optimum speed (and prop window) for speeds on the oval course as has been mentioned. If going at max speed in a straight line is your cup of tea, finding that zone involves removing the turn fin and going up in prop size in small increments until something bad happens.
Then again,
