looking for advie on next phyro
  • langevn
    • Mar 2015
    • 214
    hi everyone looking for advice in between phydro built looking advice on wich boat to buy and built my choice is in between these 4 too or is some one as better one let me know looking between 30-34 inch and please advie wich fe motor setup and prop etc recomend for been fast need to be faster the 55 mph it is appriciated to see people that have good advice
    thank you
    choice
    1-mlboatwork GP335v2 Sport 20/
    2-GP310v2 Sport 20/
    3-phil thomas stealh sport hydro
    4-Whiplash Sport20
  • JimClark
    • 5907
    You should look at classichydros.com at their wood miss k+ and they have a glass version made by Phil thomas
    Sent from my SGH-M919 using Tapatalk
    Billy Graham
    • TRUCKPULL
      • 2975
      Whiplash Sport20
      Neu 1515 - 1Y - 2200KV
      Good 200 to 250 amp ESC
      Good High C rating 4S 2P 5000's
      60 MPH range
      Larry
      • properchopper
        rcgoatbuild@snotmail.com
        • 6968
        Not that I have any bias () but here's another possibility :
        68.2mph on one 4S 5000pack
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          I've won trophies with the Whiplash & the ML GP310. So I should be bias toward them. I've also set up & run a Phil Thomas Stealth 20 but didn't really race it.
          But If I were going to build another limited Hydro I would build an Insane 30 as Tony unbiasedly suggests.
          Here in Australia we call it Restricted instead of Limited, & the specs are slightly different, but the Insane 30 is a rocket.
          • Pau7060
            • Nov 2014
            • 67
            I built a FE30 Yellow & Yellow , but all I get too do is look at it . Working 7 days a week with long hours till Mid Nov then will be retired after 36yrs , will have mega time for boating with my 5 boats . The FE30 is very very nice boat finish is superior and hull is built too last .
            • Shooter
              Team Mojo
              • Jun 2009
              • 2558
              If you are running limited (LSH), you can't go wrong with the whip20, FE30, Phil Thomas Stealth, or ML. I've seen them all run with the best of them. Winning boats run in the 50-55mph range in the straights.
              If you are running unlimited (Full P Hydro), and you want to heat race (rougher water), then you will need to build something slightly larger in my opinion. They run in the 65mph range, typically have high current draw, and cost considerably more. ML offers one. Randy is working on one, and then there is the one that I built: http://forums.offshoreelectrics.com/...ort-Hydro-2015!
              • IRON-PAWW
                • Oct 2011
                • 314
                Tony built my FE30 and the boat is the most solid one I have. And still my favorite boat by a long way. 100km/h no prob (convert to mph at your leisure). But yeah a slightly larger hull around 37 - 40in would be ideal for the windier and slightly choppier lakes I have here. The petrol guys get me on a choppy day...... but come a glassy one...... :-)
                Been on the lookout for a nice solid hull of that size for a while now.
                PERTH AUSTRALIA
                • TRUCKPULL
                  • 2975
                  Normand
                  Where in ONT. are you??
                  Larry
                  • langevn
                    • Mar 2015
                    • 214
                    i am in cornwall ontario canada
                    • langevn
                      • Mar 2015
                      • 214
                      looking for advice for this winter on those boat please loke to see what is good out there i running sometime choppy water so and looking for 30 to 34 max with type motor esc prop etc
                        For choppy water you will likely do better with a hull closer to 34". I have run the Insane and IMO it is really too small for rough water and 60+ mph. The Whips are okay but still struggle in the rough. There are several ML boats in my club and they run well in chop. One PT Stealth boat runs great in the rough but others struggle. One Delta Force 34 in the club runs surprisingly well up to 60 mph in rough water. It is difficult to pick a winner.For power a Neu 1521/1.5D (or equivalent) on 4S2P is tough to beat, the 1515 is too small IMO. I run converted water-cooled Castle aircraft controllers but in the larger hulls you could try the Castle Mamba controllers, several posters here have had good luck with them. An x450 is a good starting place, depending on the hull and how you run you could go up to an ABC 2016, perhaps bigger..
                        • properchopper
                          • 6968
                          Jay's information comes from actual long-term experience; His club races in water so choppy that would send us SoCal sissies back to the quilting party. As for myself, I don't have a P-Sport class offered so the FE30 does fine in P-Ltd BUT I intend to build a HYPER P-Sport with the DF 34" Vortex just for max grins. TP Power & Swordfish 300 lite. RTFO
                          FE30 next to the DF34 :
                          • ray schrauwen
                            • 9475
                            Nice Tony. Let us know how that build works out. I almost bit on a Df hydro but looked at the weight and thought, I'll never be able to push it with a 1515 1y and now you open my eyes up as to how I could have rigged it to work.
                            In our area of Canada choppy can be the norm in many places we run. You have me thinking.... Hmmmm....
                            Nortavlag Bulc
                            • properchopper
                              • 6968
                              Ray,
                              The DF hull weighs in on my scale at 4.0lbs. The number sounds heavy-ish but this boat should, given its air-traps and wide "armpits" air out and run light and loose with moderate power - remember when 1515 1Y's were the "go-to" P motor ? Thing is that a sport hydro needs to use its power potential not only to rip up the straights but to maintain velocity throughout the turn with the rudder & turnfin digging in. I have a motor in mind that should be perfect but other projects are taking priority at the moment.
